- Thank you received: 6
charging problum
- kawsakiman
28 Apr 2006 18:30 #43507
by kawsakiman
charging problum was created by kawsakiman
about a year ago i seen a item on e-bay that was a conversion for a kz650 to make the regulator and rectifier one unit. mine is a 77 and i'm either over or under charging all the time. i think it was about $90. without changing the entire harness any ideas how to make 2 units into 1 ? both parts are to expensive and outdated to contuine trying to solve this problum. i have a new stator($450 thank you local dealer!)i just can't figure this points in the regulator thing. is there a bolt in/wire in solution to my no charging problums?
- rammy
- Thank you received: 1
01 May 2006 09:05 #44162
by rammy
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
Replied by rammy on topic charging problum
sorry about the delay on the thread.HAVE FAITH AND YES THERE IS A beast out there that will replace both the regulator and rectifier.I instaled one on my 77kz650b1 last year and it was only around $100 from dennis kirk the part # is 20-1268 for a b-1 and 20-1248 for c-2.It is easy to install and you can use the OEM wiring
- kawsakiman
01 May 2006 13:45 #44214
by kawsakiman
Replied by kawsakiman on topic charging problum
thank you very much! i'll go order one right now!
- TonyKZ1
02 May 2006 06:02 #44406
by TonyKZ1
1997 Yamaha Seca II - mostly stock, Oxford Heaterz heated grips, a Scottoiler system. My Mileage Tracker Page
Replied by TonyKZ1 on topic charging problum
Also Tony Weeks over at
Oregon Motorcycle Parts
makes the solid state replacements for your rectifier and regulator. I just ordered a new rectifier from him for my '75 KZ400 and it works great. Plus a good warranty on it too.
Tony
Tony
