My crazy blinker problems
  • tirekicker
  • tirekicker's Avatar Topic Author
01 Mar 2011 17:50
#434269
Hello again everyone. So I replaced the set of blinkers the previous owner put on the bike (LEDs). I figured that was why none of the blinkers actually blinked and stayed solid permanently when activated. But that isn't the case, with the old fashioned blinkers installed the blinkers still stay solid when activated and the left front doesn't even work (same with the LEDs) unless I turn on the headlight (used to not work at all!:( ), then the front left stays on permanently. What really cracks me up is when I turn on the hazard switch they blink :laugh: !! except the front left of course. So summary is front left only comes on solid with headlight all the rest don't blink just come on solid when used. :unsure:
1977 kz1000 LTD
  • bearshawk
  • bearshawk's Avatar
Re: My crazy blinker problems
01 Mar 2011 18:10
#434276
flahers relays :) the little round aluminum things on the electrical panel, i had the same problem, i replaced mine and they work great
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and pods :)
1998 honda superhawk 1000-fun in the twisties :)
1982 kz1100 A2 shafty, current project
  • DoubleDub
  • DoubleDub's Avatar
01 Mar 2011 18:13
#434278
Yep, there should be two of them. One for left/right and one for hazards. If you swap them your blinkers will work but hazards won't if it's the flasher unit.
  • tirekicker
01 Mar 2011 18:22
#434280
Thanks guys, sooooo where's the electrical panel? :huh:
1977 kz1000 LTD
  • martin_csr
  • martin_csr's Avatar
Re: -
01 Mar 2011 18:56 - 11 Feb 2013 13:04
#434294
Last edit: 11 Feb 2013 13:04 by martin_csr.
  • DoubleDub
02 Mar 2011 07:00
#434396
Electrics should be under the seat or behind the side covers. I would recommend finding a service manual for your bike...best investment you'll make.
