83 kz750 n2... coils
  • purls
  • purls's Avatar Topic Author
27 Feb 2011 00:24
#433651
dyna green or grey coils?
1983 KZ750 Spectre
1978 KZ650B2A
Re: 83 kz750 n2... coils
27 Feb 2011 06:46
#433686
coil resisrance should match ign.
:unsure: what ign? oem ic, dyna-s, 2000, other?
Good Fortune! :)
  • purls
27 Feb 2011 08:00
#433700
oem ignition. lemme go take a peek at my coils
1983 KZ750 Spectre
1978 KZ650B2A
  • purls
27 Feb 2011 08:04
#433702
yes all stock ignition. going back with coils wires and plugs for now.
1983 KZ750 Spectre
1978 KZ650B2A
27 Feb 2011 08:29 - 27 Feb 2011 08:31
#433703
Am guessing '83 KZ750-N2 Spectre oem coils are 2.2 ohm, such as the grey Dyna coils shown in this link to Z1E:
Click > www.z1enterprises.com/detail.aspx?ID=1306
The green Dyna coil is 3 ohm, which might function satisfactorily in this application, and also be continued if the ignition is later replaced with Dyna-S.
Would await advice from other members and ask Z1E about it when ordering coils.
Good Fortune! :)
Last edit: 27 Feb 2011 08:31 by Patton.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
27 Feb 2011 08:54
#433713
The 3 ohm coils will be ok, and as said, good incase of upgrade later.
Higher impedence (ohms) coils than ignition is necessary. Less ohms coils will burn out ignition and/or coils as well.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • purls
27 Feb 2011 09:12
#433722
3 ohm coils it is. Also planning on dyna s upgrade, since I'm now starting to understand ignition.
7mm copper core wires?
Recommended plug numbers?
1983 KZ750 Spectre
1978 KZ650B2A
