Minimal wiring? KZ1000 P13
- pennmktg
18 Feb 2011 05:59
Building a chopper using a 94 kz1000 p13 donor bike. Wow there is one hell of a wiring harness that I don't want! lol Does anyone know what the least amount of wiring would be needed to make it run? All I want is charging, power for lights and spark. I'm new to Kawasaki so any wire color coding and other details will help a ton! Thanks in advance, Travis.
- dejavoodo41
Re: Minimal wiring? KZ1000 P13
18 Feb 2011 06:19
All I have on mine is headlight wired straight to the battery with a 3 way switch for high/low beam with the middle position being off. The tail and brake lights wired to through the ignition switch a switch for the starter. I only have 2 fuses. one for the lights and a main fuse. This setup has worked great for me and I have found that here people tend to respond better to an arm waving around than they do a blinking light. I should probably put a horn on it eventually in case I get pulled over for a safety inspection.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- pennmktg
18 Feb 2011 06:25
Do you happen to remember how you wired the engine? Right now I'm starting with the pigtails coming out of the engine. I couldn't tell what went where on the original harness. Things like voltage regulator and proper ignition wiring are my most immediate concerns. Thanks for your help!
- dejavoodo41
18 Feb 2011 13:26 - 18 Feb 2011 13:29
I'm not real sure on exactly how I wired it up as it was a couple of years ago. I basicly just started from scratch and used a generic fuse block that takes the large size blade fuses. I'm running a Dana S with the Green Coils so I wired the ignition up by instructions for that and the rest of it I just figured out as I went. ie. tail light has to be on when the key (used a generic ignition switch that I got from JP cycles) is on and wired it accordingly, the headlight I went straight to the battery so I just have to remember to shut it off when I stop riding. The only thing that I messed up on was I wired the starter straight to the battery so the engine will turn over with out the key on and since there is no clutch interlock I just make sure to put it in neutral when I leave the bike incase some idiot messes with it. Where I work I have actually came out and found on my bike. The last time they were a couple of very nice looking young ladies so I wasn't too hard on them. I guess they thought that my bike was better for sexy picture taking than the 2 Harleys and the CBR that I was parked next to.....lol Sorry I can't be more help. It was actually pretty easy once I figured out where everything was going. Just sit down and try to figure out a game plan so you have an idea what you are wanting to accomplish before you start
Last edit: 18 Feb 2011 13:29 by dejavoodo41.
- pennmktg
18 Feb 2011 16:33
Thanks again for the help man. Oh and the photo-op thing with the girls is classic! lol
