Speedo quit working a half mile from work this AM.
  • djturnz
  • djturnz's Avatar Topic Author
18 Feb 2011 04:20
#431456
We have an unusually warm day here in southern PA, so I had to ride to work. Four blocks from work, my Speedo stopped working. I eye-balled the cable at both ends when I got to the lot. Nothing looks suspicious. Is it most likely the internal cable broke? Or is there another more common fault?
1982 KZ750 (4) LTD
Re: Speedo quit working a half mile from work this AM.
18 Feb 2011 04:39 - 18 Feb 2011 04:39
#431462
Broken internal cable is the likely cause.
But would assure connections at both ends are snug.
Sometimes, especially at speedo, the knurled fastener will loosen enough to prevent engagement without falling away from the speedo.
Good Fortune! :)
Last edit: 18 Feb 2011 04:39 by Patton.
  • dejavoodo41
  • dejavoodo41's Avatar
18 Feb 2011 06:24
#431500
I actually had the shaft in the speedo drive itself break so that's something else you might want to check
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
  • djturnz
19 Feb 2011 15:38
#431892
I pulled the cable. The forked end that goes to the axle seperated from the rest. I have been considering going with a Bicycle speedo. If I do, do I need to plug the axle drive piece?
On that note, it looks like the Sygma 800 is well suited, but discontinued. Does anyone have a suggestion for another model or a source for the BC800?
1982 KZ750 (4) LTD
19 Feb 2011 19:34 - 19 Feb 2011 19:34
#431960
Would cap speedo drive rather than leave it open and exposed to water, road gunge, etc.
Click > www.z1enterprises.com/detail.aspx?ID=274
Good Fortune! :)
Last edit: 19 Feb 2011 19:34 by Patton.
  • djturnz
23 Feb 2011 07:02
#432885
I am seriously considering the bicycle speedo. I think I am going to find a cap that fits over the thumb screw portion of the broken cable and just seal it up.
I think I want a Sygma 800 bicycle computer, but they no longer make that model. I'll have to do some digging.
1982 KZ750 (4) LTD
  • 550A2
  • 550A2's Avatar
  • keep the shiny side up
23 Feb 2011 12:25
#432926
Why not just buy a new cable?
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
  • djturnz
23 Feb 2011 12:35
#432929
I have been thinking about cleaning up my gauges all winter. I'd like to find a smaller tach and move everything off the bars.
This just pushes me in that direction sooner. I do have to order some stuff from Z1E, so I may thrown a speedo cable in my cart when I do. In case I'm not ready to do it by the time inspection comes around again.
1982 KZ750 (4) LTD
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
23 Feb 2011 16:36
#432980
General Kawasaki Z1 gauge info: http://www.z1enterprises.com/reference/Z1-gauge-guide.aspx
Gauge restoration info through ZResto: www.z1enterprises.com/reference/ZResto_home.aspx
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • hocbj23
  • hocbj23's Avatar
23 Feb 2011 17:21
#432994
I have a couple of cable driven speedos for KZs and I might have a spare cable.My bike is electric so am not using.If u want to replace the cable,let me know.bj
  • djturnz
21 Mar 2011 16:10
#439443
I bought the SCHWIN bicycle computer at Wal-Mart, and installed it last week. What sucks is, I can't see it at all in low light. Also, the sample rate takes some getting used to. I ordered the speedo cable from Z1. I'd like to clean up the gauge cluster, but I'm not sure the bicycle speedo is how I want to do it.
1982 KZ750 (4) LTD
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
21 Mar 2011 16:27
#439447
yo dj!
eyeball these.
trailtech.net/motorcycle_vapor_kits.html
i have one but do not have all the functions hooked up yet.they get good reviews from a bunch of racers and visible in any light.
