where do you ground? Pictures?
  • calvin17d
  • calvin17d's Avatar Topic Author
12 Feb 2011 00:06
#430131
Can someone help with grounding and battery terminals. I have restored much of my wiring and am needing a refresher.
1976 Kz900 A4
  • Frankn9
  • Frankn9's Avatar
Re: where do you ground? Pictures?
12 Feb 2011 00:23
#430133
mine goes to the engine block just under the rear mount(78 KZ1000)on the clutch side.
  • MFolks
  • MFolks's Avatar
12 Feb 2011 09:17
#430187
The frame will be a ground reference(just like in a car).Negative will come from the (-)Black battery terminal and usually attaches to an engine mounting bolt.
The Positive comes from the (+)Red terminal and goes to the starter solenoid, from it(on the other starter terminal)it goes to the starter motor. So when you push the start switch, a coil energizes in the solenoid(the two smaller bullet connectors), pulling in bridging the two large terminals internally, completing the current path, turning the motor and starting the engine.
it's not uncommon to pull a large amount of amps when starting an engine. Add cold, thick oil,high compression and the current may cause the heavy gauge battery cables to get warm to the touch.
Some bikes have a starter interlock on the clutch lever, so it must be squeezed to start the engine.
  • calvin17d
12 Feb 2011 09:57
#430196
very helpful thanks. Do you see a ground on the same starter solenoid terminal that the positive battery leads come into?
1976 Kz900 A4
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
12 Feb 2011 11:02 - 12 Feb 2011 11:13
#430213
I cant see you suffer any longer buddy:
:laugh: Enjoy...
B)
Hmm.... that didnt work for some reason...
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 12 Feb 2011 11:13 by TeK9iNe.
  • MFolks
  • MFolks's Avatar
12 Feb 2011 11:09
#430216
Starter solenoids are usually rubber mounted to avoid vibration. The energizing coil is the two smaller wires with bullet connectors, with the two larger terminals where the heavier cables go to.
Think of the starter solenoid as a heavy duty remote controlled switch. Ii acts like a relay, but can handle far greater current loads that would burn out the contacts in a relay.
  • TeK9iNe
  • TeK9iNe's Avatar
12 Feb 2011 11:14 - 12 Feb 2011 11:44
#430218
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 12 Feb 2011 11:44 by TeK9iNe.
12 Feb 2011 12:33
#430224
As Frankn9 related, the negative battery cable attaches to the engine block.
Imo, this is better than attaching it somewhere to the frame, because it keeps the ignition continuity within structure of the engine, without risking possibility of less than perfect ignition circuit continuity between frame and engine.
If paranoid :lol: about "perfect" chassis wiring grounds to frame, could run a second wire from the engine bolt to a known good ground on the frame.
The connection will likely look something like these:
[Click on image to enlarge view.]
Good Fortune! :)
  • calvin17d
12 Feb 2011 12:40 - 12 Feb 2011 12:41
#430226
The lead which I thought might be grounding is on the top left terminal of the solenoid.
1976 Kz900 A4
Last edit: 12 Feb 2011 12:41 by calvin17d.
  • TeK9iNe
  • TeK9iNe's Avatar
12 Feb 2011 13:38
#430235
Either large terminal can go to the starter motor, and the other to the high current power source.
The S terminal is the power/switch terminal, the I terminal is for ground, and the base of those units need to be grounded as well.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • calvin17d
12 Feb 2011 15:26 - 12 Feb 2011 15:28
#430257
So can we address the items in the picture?
The red wire in the middle I assumed was a ground? Any thoughts on why the black/yellow wire is not on the solenoid and is tucked in behind its mounting ear?
I apologize. I received the bike this way. It seems all the wiring is here but in incorrect areas. Additionally, the large diameter positive (not pictured)lead (not pictured) does not have lugs which will directly fit over the appropriate solenoid terminal(diameter is too small). Me thinks that this short lead (top left) may be serving as a connection to the larger diameter positive lead which has smaller lugs than this short 12 gauge wire on the top left.
As well, the loose black lead coming from the rectifier is supposed to join in the white terminal to meet its yellow/black lead on the backside of the 6 pin connector. Looks like they wanted to ground that directly to frame. Tying this ground into the 6 pin connector would achieve an engine ground correct?
I hope that is not too confusing.
1976 Kz900 A4
Last edit: 12 Feb 2011 15:28 by calvin17d.
  • TeK9iNe
  • TeK9iNe's Avatar
12 Feb 2011 16:10 - 12 Feb 2011 16:17
#430266
:huh: I thought I did...
Large red wires were not used as grounds. Refer to to the wiring diagram I provided. They are VERY HELPFULL.
No problem... :) Looks to me that your wiring is all @#%$ed (no offence), and that solenoid unit, is not stock. Its a Ford unit scavenged from somewhere. Thats why your leads dont fit, they need to be drilled for that unit.
No. It would not make for a very good engine ground. It would just be grounding the battery to frame. The engine ground to - batt terminal should be a large gauge wire. There should also be a ground lead from batt to frame. Again, just check the wiring diagram and you can see all the required conections for ground, rectifier, regulator, everything...
Sorry, but to me the whole thing looks F'd, and all wrong. Which is why I say, hook up the solenoid like I said, and use the diagram for the rest.
Best of luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 12 Feb 2011 16:17 by TeK9iNe.
