axle mount license plate
- andy9802gt
- If it tastes that good, eat it yourself.
31 Jan 2011 11:07
All right guys, after helping my brother clean up his frame this weekend I decided to use his bike to get an idea how to put the zx12 taillight on. I noticed I'm not going to be able to mount the plate under the brakelight so I have to go with an axle mount. Question is how would you guys light it up? I don't want to run wires down my swinger or the strut. any ideas? just for a visual this is what we're dealing with.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- Frankn9
Re: axle mount license plate
31 Jan 2011 12:15
can you go through the swingarm(if its open tube)? I guess you really only need one wire.
- Kidkawie
- I bleed premix
31 Jan 2011 12:36 - 31 Jan 2011 12:37
You can go through the s/a or use little wire clamps underneath.
i114.photobucket.com/albums/n248/Jeekinz/HD1.jpg
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 31 Jan 2011 12:37 by Kidkawie.
- andy9802gt
31 Jan 2011 13:01
I just need to light the plate taillight is where it is in pic. do you guys think I could use an led under the tail aimed at the plate? I don't really wanna drill a hole in the swingarm to run the wire into if I can avoid it.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- Frankn9
31 Jan 2011 13:22
I'm lookin at your pic and it still seems like you could run a wire through the whole swingarm front to back unless your swingarm is boxed in infront of your pivot point. don't know about the LED idea, some of these new LED's are pretty bright now, but they are usually more involed than just hookin up a conventional bulb. also when I think of "aiming" an LED I think of flashlights that have things like lenses and reflectors to help aim it, I don't think a bare LED would do the same thing.
- hocbj23
31 Jan 2011 13:59
I would check ur local DMV regs re placement/lighting of the plate before u went to a lot of trouble.Dont want the gendarmes hassling u.bj
- andy9802gt
31 Jan 2011 14:10
I live in Indiana and see alot of the customs and hardlys running them vertical so why not me. There's no room under the taillight for it. I don't want a wire running down my swingarm I could run it up the strut I just don't think it would look very clean.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- MFolks
31 Jan 2011 14:18
I'd suggest using two wires(unless you're going to have a brake light there too), and then it would be three wires,
Grease from pivots make for bad grounds along with the axle stuff, so adding a ground wire will ensure the volt get to the circuits.
I'd stick with the standard Kawasaki wire colors if possible:
RED,the tail light or running light circuit
BLUE(sometimes with a RED stripe), the brake light circuit
BLACK with YELLOW stripe,the ground circuit.
Probably three 18 gauge wires will be more than enough for the lighting needs. Get an electric drill and twist the three colors of wire together, and then cover them with heat shrink tubing.
- stonemaster
31 Jan 2011 14:36 - 31 Jan 2011 14:43
andy9802gt wrote:
+ 1 on thruogh the swingareI live in Indiana and see alot of the customs and hardlys running them vertical so why not me. There's no room under the taillight for it. I don't want a wire running down my swingarm I could run it up the strut I just don't think it would look very clean.
Last edit: 31 Jan 2011 14:43 by stonemaster.
- andy9802gt
31 Jan 2011 14:46
stonemaster wrote:
I have an aftermarket axle that has two flats and a lockwasher so I'll just remove one of the flat washers and use the mount in it's place. I guess I could mount it to the upper part of the strut, after all I don't ride on the back.
andy9802gt wrote:I run one so really why not ??, mine's mounted to the frameI live in Indiana and see alot of the customs and hardlys running them vertical so why not me. There's no room under the taillight for it. I don't want a wire running down my swingarm I could run it up the strut I just don't think it would look very clean.
I ran my wire in the frame figured out location, drilled holes, pulled wire, one of the easiest parts of that build :woohoo:
if u do axle, fab something, u'll have to do a longer axle, easy enough, shouldnt be hard, u could still run wiring in frame just leave a little slack
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
