Timing advance springs,,,
  • me109g4
  • me109g4's Avatar Topic Author
25 Jan 2011 17:22
#425455
Evening, i was looking at the advance springs on my 80 KZ1000 LTD and one looks a little stretched out, I would like to replace them does anyone know where i could get a set? I would prefer new if such a thing is possible. Thanks,, JT
  • MFolks
  • MFolks's Avatar
Re: Timing advance springs,,,
25 Jan 2011 17:57
#425479
One of the two forum members either "Loudhvx" or "Otakar" touched on this some time ago. I'd write them and ask if they found a source.
I think one of them found a custom spring maker, but I'm not sure.
  • stonemaster
  • stonemaster's Avatar
25 Jan 2011 18:28
#425501
you likely will have to get entire advance unit, probably easier IMO
  • gearheadmm
  • gearheadmm's Avatar
  • MUCH MORE BOOST..........I mean BRAVO
25 Jan 2011 19:48
#425542
Get a kit for a small block chevy. HEI dist I think, very common and cheap. They come with several tension springs for "recurving" your advance curve
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
  • bountyhunter
  • bountyhunter's Avatar
25 Jan 2011 21:17
#425588
I found some springs at Orchard Supply that were close to mine and I was able to make some. They are very thick wire and not easy to bend.
  • bountyhunter
25 Jan 2011 21:19
#425589
Yes, Kawi never sold the springs alone. I believe the advancers are "calibrated" for advance by bending the spring coils apart. Mine was.
