Speedometer whirring noise
  • gabriel
  • gabriel's Avatar Topic Author
25 Apr 2006 10:45
#42530
I have an '84 ZN700 shaft and when it's cold, let's say in the 40's, the speedometer makes this loud whirring noise. It starts around 35-40mph and it stops as soon as I go under 35mph. The needle is not jumping up or down or anything like that. I opened the gage assembly about 1 month ago and lubed all the little gears over there.
Anybody has any idea?
  • Werewolfx
  • Werewolfx's Avatar
Re: Speedometer whirring noise
25 Apr 2006 11:56
#42544
My speedometer started doing the same thing, hot or cold, above 20 mph. It got louder and louder til finally it was loud enough people would look to see wth that sound was as I rode by..I disconnected my speedometer cable at the fork, sound gone. Reconnected it at the fork, disconnected it at the speedo and tied it out of the way, sound still gone. I took the cable off and haven't looked back..Course, my speedo needle was broken too, so I didn't lose much ;)
I'll eventually replace my speedo/tach with one from Electrosport.
Chris
  • RonKZ650
  • RonKZ650's Avatar
25 Apr 2006 12:01
#42547
Not sure the exact setup on your particlar bike or what exact gears you lubed, but if it's similar to the older bikes, the noise is generated right where the cable goes into the speedo. Take the speedometer off, turn it upside down, spray a little oil around the edge of the part the cable spins in the speedo and problem will be gone. At least that's the hope we have.
  • gabriel
26 Apr 2006 10:25
#42837
I have the original speedometer and cable. I lubed all the little gears that seem to reduce the rotational speed so that a meaningful reading shows on the speedometer.
I'll try your solution, Ron, and let you know how it goes. I've seen a ZN gage cluster on e-bay for $99+S/H but I'm not going to invest more money in this bike.
Gabriel
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
26 Apr 2006 20:11
#43022
Gabriel,
The speedo on my ZN700 has been making the exact same noise. The only difference, is that the needle flutters on mine above a certain speed. It doesn't stay like that permenantely, and usually only does it when it's cold out (below 50F).
I'm going to be tearing it apart and go through it hopefully sometime next week to see if there's anything that would be causing it to do this, so I'll update what I find about it then.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • gabriel
01 May 2006 07:32
#44135
Well,
"Unfortunately" the weather improved and we're in the 60's here in Lansing, MI. So the noise dissapeared before I tried any of the solutions. I guess it will show up again in the fall. But then I'll be prepared.
Thanks to all of you that replied to my posts.
