Need Help please! compatability
- BiggDogg
25 Apr 2006 09:56
Hello, New to the forums. I would like to know if the points and coil packs are innerchangeable from a 1981 kz650 to a 1978kz650 the 79 is mine and I have a chance to buy the 81 for a C-note. It is a complete bike eccept no seat!
Post edited by: BiggDogg, at: 2006/04/25 13:23
- OKC_Kent
Re: Need Help please! compatability
25 Apr 2006 10:43
I think the 81's had electronic ignition, not points. Either way the answer is yes. Matter of fact, I put electronic ignition from a newer 550 and 750 on my 78 points engine.
Cashion, OK
78 KZ650 B2 85,000+ miles
- KitNYC
25 Apr 2006 10:44
It's worth more than $100 for parts, & you might be able to find a seat for cheap on eBay. I don't know about the coils, though. I do know that on the little twins, they switched from points to electronic ignition in 1980, so you're in the grey area with those bikes. Hopefully, one of the 650 guys will jump in & tell you. (Or you could look up the part numbers on the Kawasaki site.)
Cheers,
-Kit
Cheers,
-Kit
- BiggDogg
25 Apr 2006 21:51
Thanks for the info will definately help! the guy said the motor is low mileage but has set without plugs for awhile in the weather, but I think a little deasle fuel will free them up enough to crank it over that is prolly worth $500 or better plus a couple hundred for the frame and tank and all the cables,tires, wheels, etc...I do appreciate the help and I will keep yall up to date on my progress,Thanks again!
- rstnick
26 Apr 2006 08:13
Welcome and give us some pix when you can.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- BiggDogg
29 Apr 2006 20:46
The best I can do for ya on pics is My Avitar Mine is pretty much factory stock, same color, spokes and all.
