kz750 wont start in the winter HELP
- kz750bobber76
22 Jan 2011 22:05
hello im am new to the site and was hopping someone could help me out. i have a 76 kz750 twin and cant get it to start. it was running fine before the winter and now cant get it to fire. there is a new ignition coil, spark plugs, rebuilt starter and had the engine tuned and carbs rebuilt in sept. i let it sit in the garage for a few month and just tried to start it and nothing. the starter cranks but wont fire up. i do live in buffalo and its cold and help would be great.
- dblhdr
Re: kz750 wont start in the winter HELP
22 Jan 2011 23:15
It goes without saying but I'll say it any way. :blush:
Make sure you are getting spark to your plugs, and check to make sure there is fuel in the tank and the pet cock is not turned off, and the fuel filter isn't clogged, and you have the choke all the way on.I would put the fuel petcock on prime. Also make sure the battery is fully charged. Those are the basics and the problem could easily turn out to be very simple.
don't forget to check all the vacuum lines also to make sure one didn't come off. If all that checks out ok stick with this board the guys here will be able to help you along :lol:
1981 KZ1000 Police Special coverted for civilian use with passenger seat, custom luggage rack, and paint. Daily rider.
2006 Harley Davidson Road King FLHR1
- JMKZHI
23 Jan 2011 06:52
Just to make sure, it was running fine after all of the new stuff was added, correct?
How about the battery? Have you checked it?
The bike needs a good, charged battery.
- Motor Head
23 Jan 2011 07:42 - 23 Jan 2011 07:56
If it is going to sit, then one of these is a very good idea: $7.99 when on sale.
www.harborfreight.com/automatic-battery-...t-charger-42292.html
Also Have you checked to see what the voltage is at the Coils? There may be voltage loss do to poor connections/ brittle wires/ bad fuses & clips at the panel. Check battery voltage with key on and coil voltage, should be real close within .5v of each other.
Then have you turned the petcock on @ prime for a bit before cranking to ensure the bowls are full? Put the choke on and don't touch the throttle till it fires. When you cleaned the carbs was the starter circuit cleaned real good as well?
Last edit: 23 Jan 2011 07:56 by Motor Head.
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
23 Jan 2011 09:16 - 23 Jan 2011 09:18
kz750bobber76 wrote:
I own a few bikes and they get to sitting and thus the batteries get low. So I bought one of these from the local Autozone stores -- this one is the smallest version of 'portable jump starters' as it is designed for motorcycles, snowmobiles, but not big trucks or anything:
www.autozone.com/autozone/accessories/Du...entifier=298616_0_0_
It was $60, that's less than a battery. I also use battery maintainers as Motor Head suggested, but I like to be fully armed with a jump starter too.
So here's the deal. When you left your bike "sit in the garage for a few months and just tried to start it and nothing" -- that is *plenty* of time for your battery to lose some of its stored energy/voltage. That's why Motor Head recommended that battery maintainer.
You can either buy a battery maintainer, or jump starter pack, or both, but chances are -- your battery might be charged enough to make you think it's fine but if you jump start the battery with the jump starter pack your bike is going to start up fine most likely, because it ran before as you said.
If the bike ran fine before being parked, then it sat in the garage for a few months, just charge the battery up or jump it.
These batteries are the weak link in the chain as far as owning and enjoying a motorcycle -- reason I say that is, unlike a car, bikes generally don't get used as often so yours is a common problem. Having a bike and a car makes you learn about the weakness of wet-cell bike batteries -- after a few months of sitting, they lose potency, *including* a brand-new battery.
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
Last edit: 23 Jan 2011 09:18 by newOld_kz1000.
- steell
23 Jan 2011 10:28 - 23 Jan 2011 10:28
Um, guys, the 76-80 KZ750 twins don't have a "Prime" position on the petcock.
It's ON/OFF/RESERVE
It's ON/OFF/RESERVE
Last edit: 23 Jan 2011 10:28 by steell.
- Motor Head
23 Jan 2011 10:33
steell wrote:
Sorry,:blush:Um, guys, the 76-80 KZ750 twins don't have a "Prime" position on the petcock.
It's ON/OFF/RESERVE
- kz750bobber76
23 Jan 2011 18:07
thanks for all the info. i will check the battery out tommorow. makeing sure nothing is loose or not connected. will give update after doing so.
