Stray wire...battery or earth?
  • bozznut
  • bozznut's Avatar Topic Author
16 Jan 2011 16:35
#422789
Hi, bit new to all this. Sure you can help. I've been doing some light resto work on my kz750csr twin '82. Made a schoolboy error on the wiring. Just got to replace battery but have a yellow wire with a black stripe and an eye connector left over. It comes out of the main harness, just above the airbox but I can't remember where it goes. It's just the right length/position/connector to fit the batt. + terminal but can't be sure :blush: Getting to the point where I want to fire her up now and spring is around the corner!!
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Stray wire...battery or earth?
16 Jan 2011 17:39
#422804
Check you manual.
No manual,maybe a file in file base
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Motor Head
  • Motor Head's Avatar
16 Jan 2011 18:15
#422811
If you mean Black with a yellow stripe, then it should be a ground/ earth wire.
  • bozznut
18 Jan 2011 05:08
#423218
Thanks, but the black and yellow is on the negative side. This is yellow with a black stripe...book says yellow is ignition (doesn't say yellow and black..grrrr!)
  • bozznut
18 Jan 2011 05:14 - 18 Jan 2011 05:20
#423220
Gonna try and upload a pic later
Last edit: 18 Jan 2011 05:20 by bozznut.
18 Jan 2011 09:19
#423271
Check the wiring diagram in Filebase under KZ Information.
Looks to be an negative ground terminal available for an electrical accessory.
Good Fortune! :)
  • bozznut
18 Jan 2011 11:36
#423289
brilliant! thanks for that....couldn't find the file earlier and the one in my book is in black and white with no codes!! Another satisfied kz rider B)
