good stator connectors?
- camaroguy
14 Jan 2011 13:54
Where is the best place to get brass stator connectors.Ive tried everywhere locally.no such monster.mine are ok just want to cut wire from stator side back a little. wires are kinda hard.would like to get back to the soft wire.
- Motor Head
Re: good stator connectors?
14 Jan 2011 14:43
www.oregonmotorcycleparts.com/connectors.html
www.vintageconnections.com/
Here is a couple, MFolks has a whole list in a bunch of his Electrical posts.
- MFolks
14 Jan 2011 16:09
These ones?
Electrical Connectors, Wire, And supplies
www.easternbeaver.com
www.z1enterprises.com/catalog.aspx?pid=KPEL1
www.vehicle-wiring-products.eu
www.electricalconnection.com
www.electricalconnection.com/electrical-components/hitachi.htm
www.delcity.net
www.digikey.com
www.waytekwire.com
www.alliedelec.com
www.mouser.com
www.terminalsupplyco.com
www.pbase.com/mainecruising/wire_termination&page=1
www.crowbarelectricalparts.com/butt_connectors.htm
www.terminaltown.com
www.electerm.com
www.wiringproducts.com
www.autoelectricsupplies.co.uk
www.painlessperformance.com
www.rallylights.com
www.ratwell.com/technical/Terminals.html
www.economycycle.com/servlet/the-Bullet-...lectrical/Categories
www.surplussales.com/SolderlessTerminals/WireTerminals-3.html
www.findtape.com/shop/product.aspx?id=32...&width=1436&height=0
www.repairconnector.com/index.cfm/fa/cat...main/parentcat/22545
www.delcity.net
www.digikey.com
www.waytekwire.com
www.alliedelec.com
www.mouser.com
www.electerm.com
www.rallylights.com
- Motor Head
14 Jan 2011 16:20
See,
- MFolks
14 Jan 2011 17:16
When I was in the USAF(1966-1974),I worked on F-4C/D/E/F&G versions of the Phantom II at my last duty station.
when replacing the relays in the Amament Control Relay Panel, the defective relay was removed and the new one was installed using non insulated butt splices and then was covered with a heat shrinkable closed end tube.
This made the connection vibration and water resistant.
The butt splice was crimped using a Nicopress 17BA non insulated crimping tool.
These butt splices come in many sizes, it depends on how many wires you need in the connection.You can do what I call a stub crimp where all wires come together on one side of the splice, or do it the traditional way by having the wires come in from both sides.
For repairing the alternator output wiring, I'd suggest removing the insulation from the wires,crimp on a butt splice and then cover it with a good grade on heat shrink tubing.Probably 14 gauge appliance wiring will be more durable than what's available from the local auto parts store as it has better insulation for higher temperature work.
- camaroguy
15 Jan 2011 03:28
thanks alot. if I cant find it with all these links it cant be had.much appreciate.
- TeK9iNe
- What did you do!?!
15 Jan 2011 10:37
Solder and shrink-wrap.
I'm just a connector hater! :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
