Pulsing lights due to faulty regulator?
- KZCM
12 Jan 2011 12:34
Hi folks,
I'm currently in the disassembly stage on a 1980 KZ1000 shaft. The bike has about 33000 miles on it and probably has most of the problems one would expect for its age and neglect. I took a quick ride when my son brought it home and all the lights pulsed like crazy. It was the most pronounced at idle but still continued under acceleration. The low beam wasn't working so I used the high beam only to have that blow out as well. No horn either. It's going to be awhile before going back together, but I'd like to have an idea of what might be causing this before I get to that point. Any suggestions? We put a new fully charged battery in before the test ride so that's about the only known good player at this point.
1977 KZ1000 - Wish I still had it
1980 KZ1000E2 - My project
- MFolks
Re: Pulsing lights due to faulty regulator?
12 Jan 2011 13:11
Condition of the battery? A bad battery can cause this problem as it acts like a surge tank to store excess energy.
Alternator Testing For the Older 4’s(Z1’s,Kz 900’s, Kz1000’s,Kz1100’s and GPz1100’s).
To check to see if the alternator is working you need to follow these simple steps:
1. Fully charge the battery as this will be the power source during this test.
2. Disconnect the Regulator/Rectifier at the plug that has the six wires in it.
3. Start the engine and let it warm to operating temperature.
4. If you're worried about overheating, position a large fan for cooling the engine.
5. After the engine has reached operating temperature, have a helper assist you, and using a multi-meter, read the output at the three yellow wires (or the alternator output wires)at the disconnected connector.
6. Raise the engine speed to 4000 rpm, and see what the three YELLOW wire combinations(or any alternator output wires) are(1-3, 2-3 & 1-2). The output will be around 50 Volts A.C.(Alternating Current). BE CAREFUL, AS THERE IS A SHOCK HAZARD HERE!!
7. If any of the combinations are low or non-existent, the stator(wire windings) are bad and must be replaced.
Some of the older Z1’s and KZ900’s were phase sensitive, so check the wire colors carefully.
8. Using an OHMETER, Check the three wire combinations again, looking for a reading of 0.36 - 0.54 OHMS. If the readings are above or below, the stator may be bad and need replacement. Also check from any of the three YELLOW wires to ground, this will show if arcing took place.
9. Before ordering a new stator, check the connections from the stator as there are electrical "Bullet" connectors that may be damaged or dirty.
Inspect the wiring for signs of shorting or overheating too. www.z1enterprises.com sells replacement rubber grommets for the alternator output wiring, they get hard and could leak oil after a while.
10. Check the wiring coming out of the grommet as there have been situations where the wires were damaged causing a short(I.E. twisted together with insulation damage).
11. The sprocket cover will have to be removed to access the electrical connectors coming from the alternator, the left foot peg assembly and shifting lever will have to come off also.
__________________________________________________________
Alternator Stator Replacement On the Older 4’s
Source for replacement Stators
A. www.electrosport.com (They have a trouble shooting page)
B. www.customrewind.com
C. www.rmstator.com
D. www.ricksmotorsportselectrics.com
E. www.regulatorrectifier.com
1. If by testing either by checking the output voltage from the stator or by using and ohmmeter for resistance and the stator is determined to be bad, replacing the stator is not a difficult job.
2. The motorcycle owner should have on hand a replacement alternator gasket as it will tear on removal and leak if reused.
3. Put the bike on the center stand if possible and lean it to the right to minimize the oil volume that could come out when the alternator cover is removed.
4. Have selection of Metric wrenches and sockets along with Metric Allen keys to be able to accomplish this repair. ¼" and 3/8" ratchets and extensions may be needed along with Allen bits.
5. Remove the gear shift lever, the sprocket cover and possibly the left foot peg assembly.
6. A catch pan for what little oil will be lost should be positioned under the alternator on the left side. Newspapers will soak up any oil lost or some kitty litter will do as an absorbent.
7. Remove the alternator cover fasteners, some bikes use a socket head cap screw(Allen type) and others use the Phillips head type, the #3 screwdriver bit fits best for those. Use a small dish or can to collect the removed fasteners from the parts to prevent loss/damage.
8. The alternator stator is secured to the inside of the cover usually with three Allen headed bolts, Some bikes may have Torx style fasteners, Remove them and disconnect the three yellow wires that have bullet connectors on them from the bundled wires inside the sprocket cover.
9. If your bike has some color other than yellow for the alternator output wires, make note of what goes where as the older Kawasaki’s were phase sensitive in regard to the regulator/rectifiers.
10. When installing the replacement stator, clock or position the output wires and grommet so they fit into the small port under the alternator cover without being pinched or damaged.
11. Tighten the three Allen or Torx fasteners, securing the replacement stator to the cover. I like using the BLUE Loctite # 242 for hardware that can be removed with hand tools.
12. Remove the old gasket from the mating surfaces of the alternator cover and engine case by scraping with a piece of sharpened plastic like Lexan or Plexi-glass as these will not gouge the soft Aluminum Cases. Avoid using a metal gasket scraper for this.
13. Position the alternator cover, checking for pinched wiring and install the fasteners with a little silver anti-seize on the threads, tightening to the correct torque.
14. Connect up the output wires to the mating female bullet connectors and while you’re in there, check the routing of the wire bundle that runs through there.
15. Inspect for signs of heat damage to the wire insulation and vibration damage too.
16. The side stand switch, neutral switch, and oil pressure switch wiring are all bundled with the alternator output wiring running above and behind the engine output sprocket. This bundle runs in a channel as it goes up toward the various electrical connections.
17. The regulator/rectifier plug on the 80’s bikes usually has six wires in it:
A. One (1)WHITE with RED stripe, this is the bikes main power wire usually 12 gauge in size.
B. One(1) smaller Brown wire, probably 18 gauge or so, the voltage sense wire for the regulator/rectifier, helps keeping it from overcharging the battery.
C. One(1) BLACK with YELLOW stripe wire, part of the ground circuits, maybe 16 gauge in size.
D. Three(3) YELLOW wires, maybe 14 gauge in size, the alternator output wires going to the regulator/rectifier which converts the Alternating Current(A.C.) to Direct Current(D.C.) using rectification, producing the power to run the motorcycle and charge the battery.
18. Reinstall the sprocket cover, again checking for pinched wires before tightening. Install the shifter on it’s splined shaft checking for proper location, and the left side foot peg assembly.
19. Except for the minor oil spill and reluctant fasteners, it’s not a very difficult job to do.
C. www.rmstator.com
- KZCM
13 Jan 2011 12:33
Thanks for the info. It'll probably be awhile before I have her running to perform all the tests. I'm just looking ahead to be prepared. Either way, Murphy will throw something that I wasn't prepared for.
- MFolks
13 Jan 2011 12:50
The charging systems on the older Kawasaki's are pretty simple,On the Kz900's,Z1's,Kz1000 and Kz/GPz 1100's, the stator has three output wires where production of Alternating Current(A.C.) is created by the result of a spinning series of magnets on the rotor secured to the crank shaft.
The A.C. is rectified to Direct Current(D.C.) and regulated to charge the battery and run the bikes electrical system.
Excess current is shed by the cooling fins on the regulator/rectifier module.
If your bike has a smaller brown wire on the regulator/rectifier conector, it needs to be connected to the battery to monitor the charge as overcharging can happen if this "Sense Wire" is not in the circuit.
- MFolks
13 Jan 2011 15:41
Another thought is posibly the regulator/rectifier has failed internally putting A.C. to the battery(this will quickly cause the battery to fail too).
Go to www.electrosport.com and look at their troubleshooting page as it's very helpful in this kind of problem.
- KZCM
14 Jan 2011 08:56
Thanks again. Good info. I'd looked at the electrosport site and the procedures are all pretty straight forward. I'm leaning to a failure of the regulator/rectifier but only troubleshooting will really tell. When I removed the cover and stator, all the connections were badly corroded which tells me that probably all connections will need to be cleaned. I've read here to go with the De-oxit so as things are cleaned up, hopefully I can eliminate future problems by using it.
