Coil for my KZ250 single
  • scott s
  • scott s's Avatar Topic Author
12 Jan 2011 07:24
#421671
When I picked up my KZ250 project, it had an automotive coil hose clamped to the down tube.
I haven't been able to find a stock replacement coil on ebay, etc. I was wondering what my options are?
I found some coils for the KL600 (and other 600 cc singles), but those bikes were mostly CDI bikes. My KZ250 has points. Will the CDI coils have the proper ohms to run the points ignition?
And I gotta warn ya....it sorta-kinda sounds like I know what I'm talking about, but electrical is my weak point.
Where can I find an inexpensive coil for a single cylinder engine that will work on my KZ250?
Will I need a condenser?
Will a coil from a small engine, say, a lawnmower, work?
Here's a link to one of the KL600 coils:
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...EWAX:IT#ht_573wt_728
  • scott s
Re: Coil for my KZ250 single
12 Jan 2011 07:26
#421672
Oh, and if you know of a single cylinder engine from another manufacturer that may have a coil that will work....Honda, Suzuki, Chinese, moped, etc., ...please point me in that direction.
  • Motor Head
  • Motor Head's Avatar
12 Jan 2011 11:25
#421697
Go to somewhere like DennisKirk, and get a replacement single fire coil for points off of a older Snowmobile.
Somewhere here:
www.denniskirk.com/jsp/search/search.jsp...10&_requestid=277343
Might have to email for the Ohm Spec.
12 Jan 2011 12:02
#421701
What year/model bike do you have (you should put the year/model in your signature)? Different models used different coils. For example, if yours happens to be a 1981-D2 the coil (part number 21121-1043) is still available from Kawasaki. Ed
  • scott s
12 Jan 2011 13:03
#421718
The bike is 1980. It's the "D-1" model; the points fired unit.
  • scott s
12 Jan 2011 13:05
#421719
How can I find out the ohm spec for my bike? I have a manual and it's not listed anywhere. If I knew what the specs were, I could at least ask if the replacement coil was the same.
  • MFolks
  • MFolks's Avatar
12 Jan 2011 13:16
#421723
Try contacting www.z1enterprises.com as they are very knowledgeable about these older bikes.
Also try here:
autos.groups.yahoo.com/group/vintagekawasakisingles/
  • scott s
12 Jan 2011 13:40
#421726
Poring over my manual again, I see where they are checking resistance of the coil. They mention a Primary and Secindary winding (again...I don't know what that means), but here's what the manual says:
Primary winding
meter range: x 1 ohm
meter reading: 3.4~5.0 ohms
Secondary winding
meter reading: 9.1 ~14.0 ohms
That tells me I need at least a 3.4 -5.0 ohm coil, right?
  • MFolks
  • MFolks's Avatar
12 Jan 2011 13:48
#421728
Yes, primary is the small wire conections with secondary being where the sparkplug connection would go.
If possible, try to get the lower ohm coil for stronger spark.
  • loudhvx
  • loudhvx's Avatar
13 Jan 2011 03:16 - 13 Jan 2011 03:17
#421820
Any 4 ohm motorcycle coil with a single lead should work fine.
Slightly lower ohm is ok, but will shorten points life marginally.
A car coil will burn the points pretty quickly, if the coil itself doesn't overheat.
Last edit: 13 Jan 2011 03:17 by loudhvx.
