GPz1100 odd temp sensor voltage issue
  • Polar_Bus
  • Polar_Bus's Avatar Topic Author
09 Jan 2011 06:43 - 09 Jan 2011 11:52
#420946
A buddy of mine was so impressed riding my GPz1100 back last spring, he bought
one himself ! His '83 GPz1100 is in great condition and all original. However the bike has been plagued with severall running issues. The first
was the infamous rust in the tank, got that fixed, the second was a bad pressure
regulator, got that fixed, now we have a odd issue. The ECU is sending a fault
code #13 (engine temp sensor) I swapped ECU's with a know good unit and no change. I'm observing and
odd situation where there is 1.8V at the gray wire with the ignition key "off".
In this condition there is not supposed to be any voltage present. That's as far
as I got, and i'll keep updating this thread as I hopefully get this issue
fixed. Any thoughts on this issue ? Thanks!
Rich
Bikes:
'84 GPz1100
'06 HD Fatboy
Last edit: 09 Jan 2011 11:52 by Polar_Bus.
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
Re: GPz1100 odd temp sensor voltage issue
09 Jan 2011 09:47
#420990
I don't know the answer to your problem but if it turns out that the sensor is bad I have a new one. As far as I know they are no longer available from Kawasaki.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
09 Jan 2011 10:09
#420994
May help: I believe its same as GPZ...
Your control unit could be bad. :unsure:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Polar_Bus
09 Jan 2011 11:50
#421011
I have a complete set of known good gpz1100 electronics, and I swapped ECU's and no change. Same fault code. I also swapped a spare temp sensor, and still nothing.
Bikes:
'84 GPz1100
'06 HD Fatboy
  • MFolks
  • MFolks's Avatar
09 Jan 2011 12:03
#421016
If it were me, I'd be pulling the fuses one at a time to determine what circuit is powering the sensor. Sounds like a wiring problem crossing over from another circuit.
  • Motor Head
  • Motor Head's Avatar
09 Jan 2011 13:00
#421040
Maybe some of these from the FSM will help. Notice the Power/ Fuel pump relay has diodes. You should be able to check the system from the Computer/ ECM connector and pin everything out. Do you already have these tests in a FSM?
  • Motor Head
09 Jan 2011 13:01 - 09 Jan 2011 13:03
#421041
Also the Temp Sensor pin-out.
These are from a pdf service manual available for download on KZR, I've found it and posted the link a couple of times, search kz1000 pdf.
Last edit: 09 Jan 2011 13:03 by Motor Head.
  • Motor Head
09 Jan 2011 13:26
#421047
Oh and here is the ECM connector pin-out.
  • Motor Head
09 Jan 2011 13:30
#421050
And the Diagram for the injection System.
  • Polar_Bus
09 Jan 2011 14:57
#421064
Thanks Motor Head for posting up the wiring diagrams, and yes I do have the KZ base manual and the GPz suppliment manual to help me figure this out. I played around a bit today, but dam it's cold and I can't work very long, but I swapped the CDI as another simple swap, and nope not the CDI. I also pulled all the plugs and they are sooty rich black. As I understand as soon as the ECU sends a fault code the DFI goes into "safe" mode which sounds like an rpm limiting very rich safety condition, so this is probably what's currently happening. Like Mfolks commented next step is to start yanking fuses to try and isolate the circut. I'm also going to inspect for a fried wire(s) or corrossion .
Rich
Bikes:
'84 GPz1100
'06 HD Fatboy
  • Motor Head
09 Jan 2011 15:02
#421066
Follow the pin-outs from the ECU connector. Make sure that the grey wire has no other continuity except when hooked to the temp sensor. Check the sensor resistance as shown from the ECU connector. Make sure those voltage feeds to the ECU good dead at key off. Only external diodes I see are in the relay. But corrosion either in the harness or the ECU itself could back feed some voltage.
Good you have the FSM.
  • MFolks
  • MFolks's Avatar
09 Jan 2011 18:31
#421111
