Stator question
  • 2bskor
  • 2bskor's Avatar Topic Author
Stator question
07 Jan 2011 08:12
#420518
I am looking at buying a stator off of ebay for my 1979 kz1000st. It is like finding hens teeth!! There is one from a 1980 z1r that looks the same from what I can see. Does anyone know if they would be the same?
1979 KZ1000ST (Canadian) Electronic Ignition, 4 into 1 header,K&N air filter
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Stator question
07 Jan 2011 08:26
#420521
The 1000 st doesn't have any interchangeable parts with other models - so far as I know....
They were never made before, and none after either.
Someone might have another opinion, but I think this would be your best bet: Call Jeff @ Z1 Enterprises
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Re: Stator question
07 Jan 2011 12:52
#420595
kawasaki.com shows the same stator and rotor on 11 models.
KZ1000-E1 (Shaft) (1979)
21003-1015 STATOR ASSY
21007-1011 ROTOR
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
KZ1000-D3 (Z1R) (1980)
KZ1000-E2 (Shaft) (1980)
Lots of good info on kawasaki.com, including parts diagrams, part numbers, models sharing same part, availability, etc.
Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Good Fortune! :)
  • 2bskor
Re: Stator question
07 Jan 2011 17:58
#420652
Thanks for the info. I do look at the Kawasaki site but I didn't see that info there, so again thanks :lol:
  • gearheadmm
  • gearheadmm's Avatar
  • MUCH MORE BOOST..........I mean BRAVO
Re: Stator question
07 Jan 2011 18:36
#420657
MKII
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
  • Polar_Bus
  • Polar_Bus's Avatar
Re: Stator question
10 Jan 2011 11:54
#421250
If you can't find one I have a good spare from a GPz1100 that should be the same. I can post up some pics and measurements top see if it matches yours.
Bikes:
'84 GPz1100
'06 HD Fatboy
  • 2bskor
Re: Stator question
10 Jan 2011 12:16
#421252
I found one on ebay. Thanks for the info so long as the one I got fits I should be good to go :o)
  • 2bskor
Re: Stator question
23 Jan 2011 19:25
#424886
Charging she is. Good to go, so there are some interchangeable parts out there for the old kz100st's
  • JMKZHI
  • JMKZHI's Avatar
Re: Stator question
24 Jan 2011 08:41
#424942
A cross-reference is available in the Kaw diagrams.
Sometimes the diagram reference numbers are clickable, which speeds up finding the full part number below.
Click the part number - a new window opens.
Parts listed as Active might still be available at the dealer.
Click the yellow/black ? in that window - another new window opens showing what models use that part.
Click the red/white S for part number supersession.
  • NZGlenn
  • NZGlenn's Avatar
Re: Stator question
20 Feb 2011 00:43
#432021
Hi,
I had the stator rebuild by my local electric motor rewinder. Still going strong 25,000 miles later.
Glenn
1984 GPz1100A2
  • nuwonder
  • nuwonder's Avatar
Re: Stator question
17 May 2016 06:58
#726955
Hi!
Was this indeed the mk2 rotor which fitted in this? I'm having a hard time finding rotor for my 1979/80 mk2 :(
The help link to kawasaki site doesn't help, do they still provide info? I was trying their main page but didn't find any info on older models.
-Sami
The following user(s) said Thank You: MDZ1rider
  • MDZ1rider
  • MDZ1rider's Avatar
Re: Stator question
17 May 2016 08:35
#726971
That link was over 5 years old. Kawasaki.com dropped the parts list a little while ago. You can still research part number on several Kawasaki OEM parts sites. I use Partzilla.com. The models sharing this same stator originally posted by Patton is still good.
