No neutral light?
- EvD
No neutral light?
05 Jan 2011 11:24
Hey, I am building a kz900 bobber and i want to put a neutral light on it. The problem i am having is there is only one wire coming out of the motor for the light and i checked it on my meter with juice being sent to the motor in neutral and out of neutral and still no power. Any HELP or thoughts would be great. thanks
- testarossa
Re: No neutral light?
05 Jan 2011 12:22
EvD all that the neutral switch does is ground to the motor when the bike is in neutral. You can test it by connecting your test light to the positive terminal on your battery, and then touching the wire coming from the switch. The test light should illuminate when the transmission is in neutral, and not in any other gear.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
