LED Conversion
- larrycavan
Re: LED Conversion
27 Mar 2011 20:38
www.hidnation.com/mohidki.html#
Haven't looked into this to any depth yet... but price seems unbelieavble :unsure:
- bountyhunter
Re: LED Conversion
27 Mar 2011 20:53 - 27 Mar 2011 20:57
server lockup duplication
Last edit: 27 Mar 2011 20:57 by bountyhunter.
- bountyhunter
Re: LED Conversion
27 Mar 2011 20:54 - 27 Mar 2011 20:56The 120 degree angle is plenty because the turn signal/tail light lenses diffuse the light. They are so bright they are actually much more visible than the standard bulbs from all directions.otakar wrote:bountyhunter wrote: The luxeon 3W LED bulbs at superbrightleds.com are brighter than a standard 1157 bulb. I have five of them on my KZ-750. Use a solid state flasher and chuck the external resistors.
Those bulbs are only 30/85 Lumens and also are only 130* beam angle. That will give you a hot/bright spot on the middle of the signal and not much more. The bulbs I have are 360* viewing angle and work extremely well in a reflector (or without) and are 100/200 Lumens (1157). I also have some 125/250 Lumens bulbs with a 300* beam. Those are very nice.
As for lumens: all I know is you had best not EVER look at them without a lense filter in place or you will be seeing spots for a long time. They are blindingly bright.
Last edit: 27 Mar 2011 20:56 by bountyhunter.
- larrycavan
Re: LED Conversion
27 Mar 2011 21:36larrycavan wrote: www.hidnation.com/mohidki.html# Haven't looked into this to any depth yet... but price seems unbelieavble $20 :unsure:
www.xtralights.com/hidxenonmotorcyclecon...dconversionkits.aspx This link will allow you to see the differences between the various bulbs available.
