LED Conversion
- mtbspeedfreak
Re: LED Conversion
12 Jan 2011 00:48
Anyone else out there running a LED headlight? Hell, anyone have one on their CAR???
I'm a little worried about the LED projection, I have several LED headlamps (little ones, wrapped around a headband, not your auto/moto headlamp), and I definitely notice a loss of depth perception. I've never really figured this out, I have 20/20 vision without glasses or contacts, but the depth perception is whack.
Can anyone "shed some light" on this phenomenon?
2000 ZRX 1100
1976 KZ 900- Daily Driver
- otakar
Re: LED Conversion
12 Jan 2011 04:54 - 12 Jan 2011 04:59
I know that BMW has LED as an option on a few of their high end cars. I will stay wih my HID headlight. I run it as a single beam without a individual high beam. Instead of only using the top half of the reflector I use the whole reflector and have it tilted a bit more down and out, not to blind oncomeing traffic. I use the other switch position on my control to run a city light (LED), which I use during the daytime.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 12 Jan 2011 04:59 by otakar.
- mtbspeedfreak
Re: LED Conversion
26 Mar 2011 04:33
Alright, bringing this topic back
My new HID headlight kit from Otakar just arrived today, so I'm really looking forward to throwing that in and rocking. It truly is a "plug and play" kit, just as he advertised. I pulled out my Silverstar bulb and plugged in the HID light- I think the term "a night a day difference" most definitely applies. Definitely looking to getting some night saddletime in soon!
I'm on superbrightleds.com trying to figure out what bulbs, flashers and resistors I need. Otto threw in a tail light bulb, so that "end" is taken care of. What sort of resistor so I need to plug in to ensure the tail light out light won't constantly be illuminated? Will this work:
RL-2525 Marker Lamp Load Resistor
25 Ohm, 25 Watt resistors can be connected across marker lamps to simulate
the load of a regular filament bulb. Measures 1.08"L x .59"W x .62"H. Leads
are 12 inches long.
Next up, turn signal bulbs and a new "no-load" flasher unit. I pulled my flasher unit off my KZ, it appears as though this flasher will work ( www.superbrightleds.com/cgi-bin/store/in...e2Disp=/flashers.htm ):
CF12ANL-01: LED Bulb Flasher Unit
Electronic LED Flashers have no minimum load-12VDC
Eliminates the need for load resistors, turn signals will flash at normal
rate with or without LED bulbs
Now bulbs. I'd like to convert all indicator bulbs. Which option did you guys chose to replace the 3.4w bulbs? Lastly, where are these Luxeon LEDs I've heard about? I couldn't find them on the site.
Thanks for your help!
are 12 inches long.
2000 ZRX 1100
- porchev914
Re: LED Conversion
26 Mar 2011 20:17 - 27 Mar 2011 02:31
[url/]
www.ledsupply.com/
[/url] Luxeons are easy to find
FRANKEN Z!
Last edit: 27 Mar 2011 02:31 by porchev914.
- otakar
Re: LED Conversion
26 Mar 2011 22:23 - 26 Mar 2011 22:23
Yes, The CF12 flasher is the one you want. Do not use any resistors. The bulbs from Superbright really suck. I have tried every stile they have and none of them are worth a damn. I now import bulbs which put out some real light and they work well with or without a reflector in the signal housing (better with a reflective surface though)If the inside of your housing is just black plastic, the "chrome spray paint" works really well. You will get about twice the light.If you have a Brake Light warning light just remove the bulb. There is no need for it anyway.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 26 Mar 2011 22:23 by otakar.
- Old Man Rock
Re: LED Conversion
26 Mar 2011 23:23
Otto...good to see ya back.
BTW all, I've seen his head light conversion at night in ops and it truly is bright. Sax and I where like holly crap, whoa!
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
Re: LED Conversion
27 Mar 2011 00:30 - 27 Mar 2011 00:33Attachment IMG_0230_35.JPG not found
I was stopped last year by a cop for speeding at night, on my bike. He never even mentioned the light.:blush:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 27 Mar 2011 00:33 by otakar.
- bountyhunter
Re: LED Conversion
27 Mar 2011 02:56 - 27 Mar 2011 02:57
The luxeon 3W LED bulbs at superbrightleds.com are brighter than a standard 1157 bulb. I have five of them on my KZ-750. Use a solid state flasher and chuck the external resistors.
Last edit: 27 Mar 2011 02:57 by bountyhunter.
- mark1122
- Keep twisting it
Re: LED Conversion
27 Mar 2011 17:59
OTTO. I am happy with the HID i got from you.
but i must say, i miss my high beam. sometime i will get around to replacing the hid with 1 that has both high and low beams.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- otakar
Re: LED Conversion
27 Mar 2011 19:10
I've had my HID now for about three years on the bike and have never had the desire to even require a Hi beam. You might have it set too low. Put your bike so it is facing your garage door and the headlight lens is 25' from the door. The top of the bright spot of the light should be 37" from the ground. If you make it 39" you wont hurt anything. Also set it so it points a bit more to the right than would be normal. I think that you will find that you will have plenty of light for any kind of riding.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Re: LED Conversion
27 Mar 2011 19:29bountyhunter wrote: The luxeon 3W LED bulbs at superbrightleds.com are brighter than a standard 1157 bulb. I have five of them on my KZ-750. Use a solid state flasher and chuck the external resistors.
Those bulbs are only 30/85 Lumens and also are only 130* beam angle. That will give you a hot/bright spot on the middle of the signal and not much more. The bulbs I have are 360* viewing angle and work extremely well in a reflector (or without) and are 100/200 Lumens (1157). I also have some 125/250 Lumens bulbs with a 300* beam. Those are very nice.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
The following user(s) said Thank You: sashatkoff
- mark1122
- Keep twisting it
Re: LED Conversion
27 Mar 2011 19:34otakar wrote: I've had my HID now for about three years on the bike and have never had the desire to even require a Hi beam. You might have it set too low. Put your bike so it is facing your garage door and the headlight lens is 25' from the door. The top of the bright spot of the light should be 37" from the ground. If you make it 39" you wont hurt anything. Also set it so it points a bit more to the right than would be normal. I think that you will find that you will have plenty of light for any kind of riding.
i'll give that a try
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
