H.I.D. Conversion
- mtbspeedfreak
H.I.D. Conversion
27 Dec 2010 22:14
Hey guys,
Has anyone out there tried running H.I.D headlights on their KZ/Z1?
I ride my bike through all sorts of conditions, I'd really like to throw more light out in front of me (I'm running your typical 7" Sylvania Silverstar sealed beam now). I know this would be somewhat pricey and I'd have to mount different ballasts and such.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- bountyhunter
Re: H.I.D. Conversion
27 Dec 2010 23:28
Have not tried HID. You will have to deal with the extra heat and also extra draw on the alternator windings. You can "buy" a little juice by changing over to LEDs for the brake light/turn signals and running lights. I think you can save maybe 50 - 60 Watts doing that.
I just use a halogen drop in replacement headlight that is same power as stock,but about 3X brighter. Mine's a GE H6024.
- 9am53
- homebrew, and some bbq
28 Dec 2010 05:58
pm otakar, he knows all about HID and LED stuff...you can search for his thread too using the search function.
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- JMKZHI
28 Dec 2010 08:54
I don't know much about replacement motorcycle headlamps.
If you're using a standard automotive headlamp, the beam pattern may be different than a motorcycle unit. Candlepower.com is one place that has been mentioned over the years from time to time.
Candlepower.com - Motorcycle headlamps
- otakar
28 Dec 2010 17:11 - 28 Dec 2010 17:19
bountyhunter wrote:
Complete opposite, the HID only draws 30W and is cooler than a standard quartz bulb by a lot. I have now been running it for about two years and I have a whole tread about it on this web sight. just put HID in the search box. I have kits available for both the round and rectangular headlights. You must change the reflector. You can't use the stock one on the bike. You can also look at my project bike where I installed the HID.
kzrider.com/index.php?option=com_kunena&...2668&catid=11#412668
And here is the link to the HID thread.
kzrider.com/index.php?option=com_kunena&...ew&catid=4&id=348657
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 28 Dec 2010 17:19 by otakar.
- mtbspeedfreak
03 Jan 2011 00:29
I'm sure the beam patters are different for auto vs motorcycle sealed beams... but I purchased the bike without a functioning headlight, so I was more than eager to get a working light in as soon as humanly possible. Granted, what was awhile ago, I don't really think about how sucky the light is during the daytime haha.
Otakar, side note, I never heard about MSD coils either. I'll be sure to make a note of that for future reference. Would you say there's the same amount of adjustability as offered with a Dyna 2000?
I've heard about Candlepower before. You'd recommend them?
2000 ZRX 1100
- otakar
03 Jan 2011 04:08
The Candlepower reflectors are only for incandescent bulbs and can not be used with HID. They will create a blinding light for oncoming traffic. As far as MSD goes, you are speaking of two different things. The Dina 2000 can be compared to the MSD MC-4 ignition, but even than they are quite a bit different. The Dyna 2000 is a regular ignition with a lot of adjustability while the MC-4 is a high performance high output ignition. You must match the right coils with the proper ignition.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- mtbspeedfreak
04 Jan 2011 00:31
otakar wrote:
I meant the same as far as rev limiters and ignition programming with a laptop. I should have Googled it instead of being helpless
Dyna2000: www.dynaonline.com/skins/products/sportbikes/dyna_2000/
MSD MC-4: www.msdpowersports.com/mc-4.html
The MC-4 is only double the price of the Dyna2000. :laugh: The MC-3 seems a bit more comparable.
2000 ZRX 1100
