turn signals
- gengomerpyle
turn signals
13 Dec 2010 13:30
i have a 1982 gpz750r1 that the old owner took the turn signals off. i want to put turn signals back on but 1 have a problem. the idiot cut the rear tabs off so i have no way to mount them to the bike. the brake light has 2 bulbs. is there any way i can wire my turn signal wires from the harness into the brake light so i can use it as brake lights and turn signals? thanks
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- TeK9iNe
- What did you do!?!
Re: turn signals
13 Dec 2010 14:32
Yes, of course!
I know someone will pop in a diagram for it here shortly, but for now you can just look under the KZ Information tab at the top of the page, then the filebase tab that comes up. Look up your bike and there is a wiring diagram there for ya to check out, and get an idea.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- MFolks
Re: turn signals
13 Dec 2010 15:01
Can a local welder fabricate some mounts for your missing turn signals? I'd think that would be the easier way to go rather than splicing wires.
- gengomerpyle
Re: turn signals
13 Dec 2010 15:08
i was thinking about that also, bit i would have to have the tri-angle cut out to get the light to fit.
1982 GPZ750R1 ELR
1971 Honda CB750K
1971 Honda CB750K
- MFolks
Re: turn signals
13 Dec 2010 16:23
Possibly a machine shop with a stamping press could make the cutouts. Or a CNC shop could cut some for you out of steel. Bring along the signals for measurements.
Another thought would be to locate the rear brake light and turn signal assembly from a 1981/1982 GPz1100/Kz1100 as the triangle cutouts are part of the rear brake light/turn signal mount.
www.oldkawman.com might have what you need or www.oldkaw.com might too.
- gengomerpyle
Re: turn signals
13 Dec 2010 16:46 - 13 Dec 2010 17:01
now that is the ticket. that would be the easiest if i can find one.
i just emailed oldkawman to see if he has one. i see one on his site but not sure if he still has it.
1982 GPZ750R1 ELR
1971 Honda CB750K
1971 Honda CB750K
Last edit: 13 Dec 2010 17:01 by gengomerpyle.
- MFolks
Re: turn signals
13 Dec 2010 19:04
That's a good idea, as the rear turn signals are are single filiment bulb. A little creative wiring should have your problem solved.
Some aluminum angles bolted to the license plate will give your signals a place to mount.
Re: turn signals
13 Dec 2010 19:21 - 13 Dec 2010 19:22
Same idea using chrome strap formed bracket with oem turn signals (with non-stock posts) on 1976 KZ900-B1 LTD.
The formed strap bracket fits under the license tag, all the way across, between the tag and tag mount, with ends bent 90° for fitting the signals.
Rear mounted signals don't interfere with fitment of soft over-the-seat saddle bags.
The formed bracket sturdily mounted in this fashion also provides handy bungee cord anchor sites.
Last edit: 13 Dec 2010 19:22 by Patton.
Last edit: 13 Dec 2010 19:59 by Patton.
- gengomerpyle
Re: turn signals
14 Dec 2010 12:54
is that found in a hardware store? and what department would it be in?
1982 GPZ750R1 ELR
1971 Honda CB750K
1971 Honda CB750K
- MFolks
Re: turn signals
14 Dec 2010 13:05
A motorcycle accessory store might have the bracket(s). Tried
www.redlinecycle.com
www.sudco.com
www.maw.com
