dyna coils vs factory
- ace
- 78kz1000
05 Dec 2010 02:58
is there any diff between dyna(green) coils & factory replacements besides cost ??? and if i go dyna do i need to remove anything in line...ballast resistors etc?? i have a dyna s ignition...78 kz1000
78kz1000
Re: dyna coils vs factory
05 Dec 2010 04:33 - 05 Dec 2010 05:09
ace wrote:
Oem coils have integral spark plug wires, requiring a left coil (with longer wires to reach the two outside plugs) and a right coil (with shorter wires to reach the two inside plugs).
Will also need four plug caps for wires on the oem coils.
Oem coil primary winding is 3.2~4.8 ohms.
No ballast resistor involved with coil primary wiring on 1978 KZ1000.
Dyna green coils are bolt-on replacements, designed for using with Dyna-S electronic ignition.
But be careful to assure Dyna coil primary wire screw head doesn't short against the coil mounting spacer.
Would opt for a pair of Dyna green 3 ohm coils and a set of Dyna solid core plug wires (come with caps already built in), both coils and wires available at Z1E.
Click here > www.z1enterprises.com/detail.aspx?ID=210
Where cost is critical, Z1E also lists a less expensive coil, which has received some favorable reviews from KZr members.
Am uncertain, but might be this one > www.z1enterprises.com/detail.aspx?ID=2857
Here are more options from Z1E:
www.z1enterprises.com/detail.aspx?ID=4333
www.z1enterprises.com/detail.aspx?ID=4334
If wanting some resistance in secondary loop (high intensity voltage in spark plug wires) to dispel radio interference or some other reason, may choose one -- only one, without combining -- of the three common methods:
1. Resistor style spark plug wires;
2. Resistor type spark plugs (eg., NGKBR8ES);
3. Resistor caps (have built-in resistor in each cap).
Likely very little if any performance difference in spark intensity or quality, or in service lives of coils.is there any diff between dyna(green) coils & factory replacements besides cost ??? and if i go dyna do i need to remove anything in line...ballast resistors etc?? i have a dyna s ignition...78 kz1000
Last edit: 05 Dec 2010 05:09 by Patton.
- ace
- 78kz1000
05 Dec 2010 08:32
thanx alot patton,i just wanted to be sure. your knowledge base blows me away.have to ask if your real intelligent or a gearhead or both ????
78kz1000
