I had to replace all of the grounds on my 82 KZ750 ltd . When I did this I went a head and replaced the rest of the wires since I had the harness off . Everything works but something odd happened the first time I turned the key on . I am new to motorcycles . This is my first one . When I turned the key the first time the headlight light on the tack came on . From what I under stand that is meant to remind you that your low beam filament is out and you need to change the headlight . I tried the high low beam switch and you can see that both filaments are working and the light on the tack went out . I have not been able to get it to do it again . Should I worry about it ?
82 KZ750 LTD H3
