Speedo cable
  • paddlerbob
  • paddlerbob's Avatar Topic Author
Speedo cable
28 Nov 2010 17:57
#414608
Just picked up a project GPZ 550. After tearing it down and degreasing I noticed no speedo cable. I cant find where it connects to the transmission. I would think somewhere near the drive sprocket? Looking for a hint on where to look. My manual tells nothing.
  • seanbarney41
  • seanbarney41's Avatar
  • '79 kz1000 LTD '75 Honda CB750
Re: Speedo cable
28 Nov 2010 19:24
#414623
Connects to the front wheel hub, on the right I believe...
  • TexasKZ
  • TexasKZ's Avatar
Re: Speedo cable
29 Nov 2010 07:38
#414648
Looks like you need a factory shop manual. You may be able to find a free download on the 'net. Even if you have to buy, it will save many times its cost.
Re: Speedo cable
29 Nov 2010 10:09 - 29 Nov 2010 11:40
#414657
Hello, paddlerbob, and WELCOME ti KZr! :cheer:
This link to FSM may help, courtesy of loudhvx (see link in his sig)
home.comcast.net/~loudgpz/KZ5mnl.pdf
Good Fortune! :)
Last edit: 29 Nov 2010 11:40 by Patton.
  • JMKZHI
  • JMKZHI's Avatar
Re: Speedo cable
29 Nov 2010 11:14
#414660
The speedo drive unit should be located on the left side of the front wheel - the left side as you are sitting on the bike - the same side as the speedo, clutch lever, & shifter pedal.
Kawasaki.com has diagrams.
  • paddlerbob
Re: Speedo cable
29 Nov 2010 16:42
#414701
Thanks Guys, My Haynes manual didn't even mention speedometer. I know my Harley goes into the tranny.
Re: Speedo cable
29 Nov 2010 17:34
#414714
Lots of good info on kawasaki.com, including parts diagrams, part numbers, models sharing same part, availability, etc.
Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Let us know if you hit a snag.
Good Fortune! :)
