Tach removal KZ650
  • sroberts152
  • sroberts152's Avatar Topic Author
Tach removal KZ650
22 Nov 2010 00:08
#413759
I want to rip the tach out of my 650 but when I disconnect it, I get some oil leakage. Is there a cover or something I need to do to make sure this doesn't leak?
1978 KZ650SR
2001 Triumph Speed Triple i955
Past bikes - Too many to list.
Re: Tach removal KZ650
22 Nov 2010 03:50 - 22 Nov 2010 03:55
#413762
Could perhaps fab up a plug similar to that used on the large fours.
Click here > www.z1enterprises.com/detail.aspx?ID=2647
Or possibly find a leak-proof screw-on cap to replace the knurled cable attachment, which cap could block leakage through the internal seal, but likely wouldn't block leakage getting past the o-ring where the tach drive unit nests inside the engine head.
:unsure: Is there no interest in replacing the o-ring and seal to eliminate leakage in the existing tach drive?
Both these parts are inexpensive and readily available from Z1E.
When functioning correctly, should be zero oil leakage from the tach drive, even with tach cable completely removed.
Good Fortune! :)
Last edit: 22 Nov 2010 03:55 by Patton.
  • sroberts152
22 Nov 2010 08:56
#413779
I'm not sure what O-Ring and Seal you are talking of. Is this inside the engine case?
I would love to not have to put anything on it if I could, or I could do a cap.
When I mean it leaks, I mean that as soon as I unplug it, I get a small amount of oil that comes out with the cable. I'm not sure if that is just residual that will go away when cleaned and the cable out or if there is a leak somewhere or if its normal to do that.
I plan on not having a tach at all when I am done.
1978 KZ650SR
  • JMKZHI
  • JMKZHI's Avatar
22 Nov 2010 09:36
#413785
Reference the diagrams at Kawasaki.com.
One end of the tachometer cable attaches to the tach drive at the engine.
The tach drive unit at the engine has an o-ring & oil seal n stuff.
  • sroberts152
22 Nov 2010 09:42
#413786
Got it. Thank you. I kept pulling up the diagram and not knowing which of the 90 pages to look on. :)
1978 KZ650SR
