Small battery needed
- thompsonmx100
15 Nov 2010 12:22
As some of you may know I'm building a cafe racer hybrid thingy out of a gpz 750. I need a small battery. I have a ytz 10 which should be sufficient enough for power. but its too big. I was looking at a sealed lead acid battery to install. I am just wondering what i need to look for in a battery. is it CCA or Ah or both. Most of the SLA batteries dont list the CCA just the Ah of the battery.The stocker is rated at 12Ah. I am wondering if i can get away with a smaller one. Like a 5-10Ah battery. Or if combining two smaller 2Ah bateries would work. I thank you in advance for any info you can provide.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- MFolks
Re: Small battery needed
15 Nov 2010 14:01
It would be nice if your project bike had a kick starter, but unless you find an older Kz1000 (about 1977-1980 I think),you'll need the cranking ability of a good battery for the electric starter.
I'd try Yuasa batteries and see what they have. The trouble I see with using two batteries is first space;how much do you have? The second is two batteries will tax your charging system possibly causing the regulator/rectifier to run hot/fail.
- ready2ryde1985
- got to love these kzs
15 Nov 2010 20:57 - 15 Nov 2010 20:58
I am switching to a motobat, tired of replacing never starts!
Also goin to a starter out of an 02 zr7.
I think the sealed batteries are smaller but not by much.
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
Last edit: 15 Nov 2010 20:58 by ready2ryde1985.
- MFolks
15 Nov 2010 21:29
make sure to connect the batteries in parallel for 12 volts, not series as this will be 24 volts(damaging your electrical system).
The picture looks like the connections are threaded for bolts, this is the best way for maximum current flow, just make sure to cover the connections with a heavy grease for corrosion protection after all work is done.
- thompsonmx100
16 Nov 2010 05:44
Yeah i was thinking if i ran two small batteries that i would wire them in series or get two 6v and wire them in parallel. Those motobatt are pretty good i have one in all of my bikes. The last one i had in my gs went bad took it to the place i bought it and they replaced it. I then took that battery home and it didn't work. the one ihave in there now has worked good since. I've had it in there for probably about 6 months. So im not really finding any batteries that are much smaller with the same power as the stocker.Like i said earlier i have the motobatt sealed ytz10. Which is 6"l 3.5"w and 3.75"h whih is pretty small but not quite small enough. There are some that are not as wide like 2.5"w so that would get me some more clearance. That motobatt place is here in town. they sell a bunch of bike stuff now.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- Kuhntucker
16 Nov 2010 07:01
thompsonmx100, if you use 6 volt batteries, you should wire them in series and if you use 12 volt batteries, wire them in parallel, this is opposite from what you said. IMHO, you should use 12 volt batteries in paralell, that way, the internal resistance of the other battery won't be an issue.
- GPZ1100_Rider
16 Nov 2010 17:59
If your budget allows, you might want to look at Speedcell Battery Lithium Ferrous Lightweight Batteries. There's other brands, but they're pricey too.
- loudhvx
16 Nov 2010 19:41
Two 12ah, 6v batts in series would be equivalent to two 6ah, 12v batts in parallel. Both combos would be equivalent to one 12ah, 12v battery.
Two 6v in series guarantees both batteries get the same discharge/charge current.
Two 12v in parallel leaves the discharging/charging current up to each battery based on its condition and the battery voltage.
There are probably advantages and disadvantages to both setups.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- notaduc
- notaduc
15 Jan 2011 09:12
Oh, keeping the electric start.
Try this.
www.hordpower.com/index.php?main_page=pr...h=59&products_id=378
Try this.
1980 (mostly) KZ1000
- TeK9iNe
- What did you do!?!
15 Jan 2011 10:18 - 15 Jan 2011 10:31
For a 750 w/Mods...
MINIMUM - You need the crank amps = size:
YUASA BATTERIES
Battery Family: YuMicron
Battery Type: YB14L-A2
Voltage: 12
Capacity: 14
Dimensions: 5.3125" x 3.5" x 6.5625"
Weight: 7.6 lbs.
Metric Dimensions: 134mm x 89mm x 166mm
Metric Weight: 3.4 kg
Polarity:
Acid Volume: 30.4 oz.
Amps: 1.4
This is what thier site recommends for 750GPz.
I ended up using an AGM like the Motobatt, and it has been very reliable, but doesnt crank as hard as the liquid filled Yuasa I used to have.
Small batteries are crap in my opinion. They die much sooner than advertised for sure - experience! With the huge discharge required for our bikes when starting, size matters, and flooded cell batteries are best, AGM second, gelled electrolite is third.
With 2 small batteries, your increasing the number of connections/resistance. Not ideal.
Single battery is the way to go, else the manufacturers would have multiple small batteries all shrink wrapped together in some neat package for all new bikes. :laugh:
YUASA BATTERIES
Voltage: 12
Capacity: 14
Weight: 7.6 lbs.
Polarity:
Amps: 1.4
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 15 Jan 2011 10:31 by TeK9iNe.
- Jack
18 Jan 2011 10:19
Smallest, most powerfull batteries seen lately are the lithium ion like Speedcell mentioned above. Schnitz Racing is selling them or try
www.turntechbattery.com
. Not cheap but have seen them on a mid / low 8's KZ dragbike and a street driven ZX14 that runs 8:85's (no nitrous) - both users are very happy.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
