1991 kz1000p
- scootertrash
1991 kz1000p
12 Nov 2010 05:26
i got this basket case,put it together but now it only fires on and off ,i've run all the tests for,pickupcoils{when it fires} coils,ic igniter...the deal is it will firesometimes then nothing,i'll run all the tests again then i have fire for awhile,then it will stop any ideas i've not thought of????????
- MFolks
Re: 1991 kz1000p
12 Nov 2010 11:46
I'd check all the grounds before possibly tearning into wire bundles.The following probably applies to your bike:
Ignition Coil Primary And Secondary Wiring
Ignition coils on the 80’s Kz1000,Kz1100’s and Gpz1100’s are wired the same, that is as you sit on the bike, the LEFT ignition coil primary(small wires) are two wires, RED and BLACK. The secondary (or sparkplug wires) go to #1 and #4 sparkplugs.
The cylinders are numbered left to right as you sit on the seat; #1,#2,#3, and #4.
For the RIGHT ignition coil, the primary wires, again are two wires, RED and GREEN, with the secondary going to #2 and #3.
The RED wire gets it’s voltage from the run/stop switch on the right handlebar switch pod.
The BLACK and GREEN wires connect to the IC Igniter(if the bike has the Kawasaki supplied electronic ignition) it actually gives the coils their grounds to fire the sparkplugs.
Primary(small wires) side of the coils will read between 1.8 to 3.0 ohms.
Secondary(sparkplug wire ports)side of the coil will read between 10.4K to 15.6K ohms.
To stress the ignition coils, take a hair dryer, heat the coils and see if the ohm readings change from cold to hot. If they do, it’s time to buy new coils.
Keep in mind, the wiring is reversed for the 550’s 650‘s and 750‘s, that is the RIGHT coil primary will be two wires, RED and BLACK with the secondary(sparkplugs) going to #1 and #4.
The LEFT coils primary wiring would be again two wires, RED and GREEN, with the secondary(sparkplugs) going to #2 and #3.
These engines have what is known as a “Wasted Spark†that is, a sparkplug will fire during an exhaust stroke. It does no damage and many other motorcycle engines have this design.
- MFolks
Re: 1991 kz1000p
12 Nov 2010 11:55
Ohm Checking Pickup(Pulsing) Coils
The pickup coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(under a right side CD sized cover) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of 2K, check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S†electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6. Checking with Kawasaki.com website has determined that the Pick up(pulsing) coils are available . The pulsing coil # is 59026-1133 and replaces the older # 1002, 1012 which were used from the MKII motors until the 2005 P24.
7.Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
8.I'd also check the related switches,wiring and connectors related to the ignition system, such as the right handlebar run/stop and start switches.
9.If everything checks out, your ignition switch may be the next thing to check as they do wear out over time.
10.Checked the fuses and clips? If your bike has the newer "Blade" style fuse holder, I'd doubt this could be the problem,however if your bike has the older glass tubed fuses and clips, I'd replace all the fuses. I believe the designation AGX is the type used, probably 10,15,20, and 30 amp ratings. Most auto parts stores can get the AGX fuse for you.
- MFolks
Re: 1991 kz1000p
12 Nov 2010 11:58
And this might help:
www.cyclepsycho.com/kz1000p/kz1000p.html
