Z 1 900 wiring question
- lewisj
11 Nov 2010 14:41
I need some help with wiring on my 73 Z1. I should have taken pictures or good notes but its too late now. At the electrical connections under the right side panel I have a new "after market starter relay " from z1 enterprises. The large red wire goes to the battery where do the other two wires go? One is blue with a white stripe, the other is red with a white stripe. The blue and green electric connectors have two blue, two yellow and two pink wires coming out the back that are not connected. Each pair is connected together with a female bullet receptacle. The brown connector attached to the battery box has a solid black wire and a black with yellow stripe. It seems I have too many wires, the female and males connectors don't add up. I have the rectifier/ regulator combination from Z! 1 that contains the green plug. What am I missing here? HELP!
Thanks in advance Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- moneypit
Re: Z 1 900 wiring question
11 Nov 2010 15:15 - 11 Nov 2010 15:19
follow this link and put in wiring diagram and use the drop menu to get your model Its at the bottom of this page
\http://kzrider.com/index.php?option=com_docman&task=search_result&Itemid=108
hope this helps
hope this helps
2-76 kz900
St Paul MN
St Paul MN
Last edit: 11 Nov 2010 15:19 by moneypit.
