New Battery from Wallyworld
  • BARNEYHYPHEN
  • BARNEYHYPHEN's Avatar Topic Author
20 Apr 2006 09:44
#41119
Picked up a new battery from Wallyworld last night. The Wallyworld book said ??12AL2 for the KZ900 but ??14AL2 for the KZ1000. mine is 76 KZ900 but I thought the Kz 1000 battery might be a little heavier duty? Now appears it's a little taller than the ??12AL2.
If it physically fits, should I use it?
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: New Battery from Wallyworld
20 Apr 2006 15:52
#41196
Here's the specs on the two straight from the Yuasa website:
Battery Family: YuMicron
Battery Type: YB12AL-A2
Voltage: 12
Capacity (Amp. Hrs.): 12
Dimensions: 5.3125" x 3.1875" x 6.3125"
Weight: 6.8 lbs.
Metric Dimensions: 134mm x 80mm x 160mm
Metric Weight: 3.1 kg
Polarity:
Acid Volume: 25.4
Charging Current (Amps.): 1.2
Battery Type: YB14L-A2
Voltage: 12
Capacity (Amp. Hrs.): 14
Dimensions: 5.3125" x 3.5" x 6.5625"
Weight: 7.6 lbs.
Metric Dimensions: 134mm x 89mm x 166mm
Metric Weight: 3.4 kg
Polarity:
Acid Volume: 30.4 oz.
Charging Current (Amps.): 1.4
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • BARNEYHYPHEN
21 Apr 2006 06:52
#41385
4R, Thanks for the info. Very good. Is there any downside to me using the larger of the two, assuming I can shoehorn it in there?
  • loudhvx
  • loudhvx's Avatar
21 Apr 2006 06:57
#41389
Electrically, there is no problem. It's just physical. Make sure the leads don't short against anything.
  • BARNEYHYPHEN
21 Apr 2006 09:29
#41418
LOUDHVX, Thanks, I'll give it try tonight and report back.
