New Grounding bar
  • BARNEYHYPHEN
  • BARNEYHYPHEN's Avatar Topic Author
New Grounding bar
20 Apr 2006 08:42
#41104
Just for what it's worth. When I first started working on my 76 KZ, I bought 2 feet of #8 stranded copper wire, soldered a large electrical "ring" on one end and fastened it under the battery ground bolt. Routed the other end of the wire to under the seat. There I attached the wire to a 6" long (10-12 terminal/hole regular house/home GE/Square D type Grounding bar.
Now I have a very convenient place it attach any and all wires that need to be grounded.
  • loudhvx
  • loudhvx's Avatar
Re: New Grounding bar
20 Apr 2006 08:59
#41108
Sounds good! Make with the photo, already. :)
  • indykaw77
  • indykaw77's Avatar
20 Apr 2006 09:10
#41111
Good 'ol yankee ingenuity at its finest. I second that motion for photo!!
Kawasaki Motorcycles...because cars lean th wrong way!
  • BARNEYHYPHEN
20 Apr 2006 09:48
#41124
Brit ingenuity please. In fact, I may be worse than a Damn Yankee? I moved to Nashville (Franklin) and stayed. Only 20 years so far so. Another 50+ years and I could be a local.
  • DesertWizardB1
  • DesertWizardB1's Avatar
20 Apr 2006 18:33
#41250
That's a good idea. When I replaced my seperate rectifier and regulator with a combined unit it freed up some space for my coil mod relay and a positive battery voltage post. I replaced the wimpy white wire coming from the battery connection with a 12 gauge wire to the post and connected the new regulator, coils and coil relay, and my battery tender wires there. I used a piece of delrin for the insulator. It is similiar to nylon but is stronger and can be tapped to hold a thread. Here is a pic.
users.adelphia.net/~lbilling/images/motorcycle/batterypost.JPG
Len
77 KZ 1000 LTD Original Owner
