Timing light question
  • Kapahulu
  • Kapahulu's Avatar Topic Author
31 Oct 2010 16:21 - 31 Oct 2010 16:21
#410146
Up until two weeks ago, the last time I had used a timing light was probably in high school auto shop in the 70's.
I bought a used timing light from a guy and asked him how it works, he said he didn't remember. So I hooked it up to my Honda CB550 like this. Black and red clamps went to respective leads on the battery. Extra lead went onto the cylinder #4 spark plug wire. That didn't work, maybe because the insulation on the plug wire was too thick. So I connected a piece of copper wire to the plug lead and ran it to the outside of the plug wire. Then I reattached the timing light lead. This time it worked and I timed the Honda.
So I tried the same thing with my KZ1000. This time the timing light won't work.
Can anyone suggest what else I should do? I looked in the Kawasaki shop manual and it said to use the timing light per the manufacturer's instructions.
Thanks, Mike
2strokeworld.com
Last edit: 31 Oct 2010 16:21 by Kapahulu.
  • steell
  • steell's Avatar
Re: Timing light question
01 Nov 2010 07:17
#410237
Post a picture of it, makes it easier to identify.
  • Kapahulu
01 Nov 2010 12:17
#410258
Here ya go, Sunpro CP7504
2strokeworld.com
  • steell
  • steell's Avatar
01 Nov 2010 12:49
#410266
Standard DC powered inductive timing light, inductive pickups are known to break when dropped on cement floor too many times.
  • stonemaster
  • stonemaster's Avatar
01 Nov 2010 14:05
#410269
which plug ???
  • Kapahulu
01 Nov 2010 14:41
#410277
I attached the timing light to plug #4.
Also - when I timed the Honda I did drop the light - just maybe 12 inches, you never know though. You might imagine why I dropped it - removing the connection from the spark plug wire with a running engine = shock treatment!
Is there a way I can test the light when not connected to a motor?
2strokeworld.com
  • stonemaster
02 Nov 2010 05:51
#410369
try it out on the honda again or try a different plug, I think thats what i did on mine but I dont remember, if urs dont work let me know I got a new digital I'll let go Cheap, it show RPMs as well as a degree adjust, (dumbasses sent me two when I bought One ) also the pickups can overheat, another trick I heard is opening plug gap on the plug ur testing on, makes it easier for the pickup to works
  • Kapahulu
02 Nov 2010 13:35
#410428
Hi Stonemaster,
I sold the Honda. Maybe I'll try it on my car. Opening the plug gap is a good idea too.
Just rode my KZ1000 on the highway, it does pretty well but does ping a little on hard throttle when it's warmed up. I want to figure out if it's timing or jetting.
Will let you know if I need another light, thanks!
2strokeworld.com
  • Kapahulu
02 Nov 2010 15:48 - 02 Nov 2010 15:48
#410441
The problem appears to have been an operator error. Today I tried again and the timing light works.
Maybe what I did wrong before was clamp the plug wire with the ends of that clamp. Actually, the clamp is supposed to go around the plug wire, like so.
The timing was a little too far advanced at higher rpm's. I had to cut some slots in the dyna plate to allow for retarding the ignition a few degrees.
Stonemaster, thanks for the offer, I am okay though.
2strokeworld.com
Last edit: 02 Nov 2010 15:48 by Kapahulu.
  • Old Man Rock
  • Old Man Rock's Avatar
02 Nov 2010 16:31
#410446
Another to look at/confirm....
My TL inductive pickup has an arrow on it indicating clamping with arrow pointing towards spark plug...
Might make a difference in your as well...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • loudhvx
  • loudhvx's Avatar
03 Nov 2010 10:25
#410580
Some of the clamps are directional, like OMR said.
My Actron/Sunpro is somewhat sensitive to the clamp being closed all the way. If the clamp is even open a tiny bit it doesn't work.
