need feed back on this daigram please !!!
- steveo_4192003
- 77kz650b-1
19 Apr 2006 21:19
i got the bike running but it was to dark for a test drive!!! i was messing with that wire digarm (displayed on page) and thought this may work. need feed back on this diagrm please!!! if this is worng or i need more/less of any thing let me know.
just want to be able to ride at night, as well as have a brake light to. (and be safe)!
Post edited by: steveo_4192003, at: 2006/04/20 00:20
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
- loudhvx
Re: need feed back on this daigram please !!!
19 Apr 2006 22:29
Looks good to me. Make sure you run all of the grounds using wire to the bolt that has the battery ground. Frame doesn't work well as a ground when it gets most and corroded.
I would suggest the power to the rear-brake-switch should come before the tail-light-fuse. That way it won't confuse you and act goofy if the tail light fuse blows.
The only real problem is the label... it is no longer "bare minimum!"
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- steveo_4192003
- 77kz650b-1
19 Apr 2006 22:50
thanks for the feed back !!!
i will fix the lable lol!
nice to have someone who knows what they are doing, just to check over newbies plans, and give them GREAT advice thanks agian!!!!
- steveo_4192003
- 77kz650b-1
19 Apr 2006 22:59
- loudhvx
20 Apr 2006 00:57
That's it!
1981 KZ550 D1 gpz.
Other links.
Other links.
- btchalice
20 Apr 2006 01:36
wheres the ground for the taillight?
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- loudhvx
20 Apr 2006 07:36
That's the yellow/black wire coming out the top.
1981 KZ550 D1 gpz.
Other links.
Other links.
