Strange turn signal behavior
  • rtrider73
  • rtrider73's Avatar Topic Author
19 Apr 2006 20:31
#40982
Last evening all worked well.
Today I ran the bike around the block upon return I noted that my turn signals would not work. Rear lights stay dark, front signals stay on as they should as running lights. Hazards will not work, but I noted that the left turn signal indicator would light when I did try to use the hazards. All bulbs appear to be good upon inspection, I swapped out the flasher relay just in case with no change in the problem. I did have the bike on the charger this morning for a few hours otherwise no other work was performed on the bike. Methinks I have a gremlin at work in the garage. Any thoughts?
Thanks,
Rob
  • JMKZHI
  • JMKZHI's Avatar
Re: .
19 Apr 2006 21:15 - 03 Dec 2008 19:38
#40995
del
Last edit: 03 Dec 2008 19:38 by JMKZHI.
  • rtrider73
Re: Strange turn signal behavior
20 Apr 2006 05:08
#41048
Sorry Folks!
Posted this late last night and forgot to include the most basic information.
My 1979 KZ650b is where this problem exists.
~R
  • wiredgeorge
  • wiredgeorge's Avatar
20 Apr 2006 06:55
#41075
Would these be stock or aftermarket signals?
  • Sputnic81
  • Sputnic81's Avatar
20 Apr 2006 07:45
#41090
I had a similar prblem with my KZ 440. Turned out to be corroded ground wires. Don't know if you have checked that but it is a thought.
  • rtrider73
Re: (POST MORTEM) Re:Strange turn signal behavior
21 Apr 2006 17:02
#41522
Well here's an update.
The gremlins seem to have departed for greener pastures at least for the time being. Went for a ride yesterday and all worked just dandy.
I tend to agree with Sputnic81 in that this smells like a bad ground. Now I just have to find it. Thanks to all who replied.
BTW these are stock signals.
Rob
