Gas light flashing
  • KZ802
  • KZ802's Avatar Topic Author
Gas light flashing
27 Oct 2010 05:12
#409372
1980 KZ750-4 I went for a ride the other day and my gas light started flashing. So naturally I stopped to get gas. It only took 1 gallon, so apparently I didn't need gas. It has been on ever since. I checked quickly when I got home, the wires are still connected to the petcock and the instrument panel but that's as far as I got. Any ideas where to start?
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
  • JMKZHI
  • JMKZHI's Avatar
Re: Gas light flashing
27 Oct 2010 07:22 - 27 Oct 2010 07:34
#409384
Maybe a problem w the brake or brake light circuit?
On my 81 650-CSR the low fuel warning light & stop lamp indicator on the tachometer share the same lite.
If you have the Owner's Manual, it will give instructions on the functionality of the indicator lights which may lead to clues as to what to check. It could be as simple as a bad brake light bulb.
Last edit: 27 Oct 2010 07:34 by JMKZHI.
  • loudhvx
  • loudhvx's Avatar
27 Oct 2010 09:06
#409402
As JMKZHI says, it may be the brake-light filament is out.
The 1980 KZ 750H uses the same light to indicate fuel and brake light failure.
  • KZ802
28 Oct 2010 18:47
#409678
sorry connected to gas tank sensor not petcock. anyways the low gas indicator light does share with the brake light, which seems to be working fine and the brakes are fine....
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
  • loudhvx
  • loudhvx's Avatar
28 Oct 2010 19:02 - 28 Oct 2010 19:05
#409679
Alright, then it's either the fuel sender is bad, or the brake light failure device is bad, or possibly a wire is broke on the brake light system.
To check, disconnect the green/white wire at the fuel tank.
If the light stops flashing then the sender is bad or shorted.
If the light keeps flashing, then disconnect the brake light failure unit. It will look like a relay with three wires: Blue, black/yellow, green/white. The light should now stop flashing.
Reconnect it, the light will once again flash. Make sure the black/yellow wire to it is grounded.
Somehow ground the blue wire using a jumper of some sort. If the light stops flashing, there is a break in the blue wire running to the bulb, or the bulb is not grounded well.
If the light keeps flashing, and the brake light filament is for sure good, probably the brake light failure unit is bad.
Last edit: 28 Oct 2010 19:05 by loudhvx.
  • JMKZHI
  • JMKZHI's Avatar
29 Oct 2010 07:54 - 29 Oct 2010 08:09
#409742
Yeah, I figured you meant the wires to the sensor.
You say the brakes are fine, but what about the brake light stop lamp in the tail lite?
Last edit: 29 Oct 2010 08:09 by JMKZHI.
