generater wireing problem on kz900 1977
Re: generater wireing problem on kz900 1977
23 Oct 2010 06:11
For reference, here's a link to the combination rectifier/regulator unit listed at Z1 Enterprises.
Using the stock connectors should help avoid concerns about the different wire colors involved.
Click > www.z1enterprises.com/detail.aspx?ID=1873
- loudhvx
23 Oct 2010 08:27
The box with black/blue/yellow/red and black/green/black/red(maybe yellow) sounds like the ignition module. That is not a regulator/rectifier combo unit, but we would need pictures to be sure.
A reg/rec combo unit will likely have 3 yellows, and probably a black, a white or red, and maybe a brown.
So it sounds like you have an ignition module and no regulator or rectifier then.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
23 Oct 2010 09:58 - 23 Oct 2010 09:59
No eBay APP ID and/or Cert ID defined in Kunena configurationHere are pics of igniter (ebay) and combo reg/rec (Z1E):
[Click on image to enlarge view.]
Last edit: 23 Oct 2010 09:59 by Patton.
- loudhvx
23 Oct 2010 11:24
I'm not sure that is the right igniter. It should have 8 wires. That one appears to only have 6 wires, and the box doesn't look like the ones I'm familiar with.
1981 KZ550 D1 gpz.
Other links.
Other links.
23 Oct 2010 12:53
Earth to Patton! :ohmy:
Just dawned on me that Kawasaki retained the points ignition system 1973 Z1~1978 KZ1000, and adopted the i.c. igniter style electronic ignition on 1979 KZ1000.
I may be confusing "ignition module" with "i.c. igniter." :S
Dale -- it would be helpful to know exactly what ignition system is currently fitted on the bike (which originally came with a points ignition).
But the points ignition may have been replaced with an electronic ignition such as later model Kawasaki i.c. igniter style electronic ignition, or a Dyna-S electronic ignition, or some other style electronic ignition.
If uncertain about which ignition is currently fitted, remove the points cover (just two screws), and describe for us what is seen. Which might be one of the three versions shown in the following pic. But it might be something else.
Where a Kawasaki i.c. igniter style electronic ignition is used to replace a points system, an i.c. igniter unit is also part of the system. The i.c. igniter does not fit underneath the points cover.
Each system has its own wiring variation.
[Click on the image to enlarge view.]
- dale7426
24 Oct 2010 02:17
ok thanks for the sckooling bros i got it figuied removed a part i needed and found out what the igniter is problem solved bike runs good thanks for all your help well defently talk to youall again
