Acewell owners, I need your help.
- testarossa
Re: Acewell owners, I need your help.
12 Oct 2010 18:22
mark1122 wrote:
Maybe you could similarly hollow out the tack. Seal it and the cable housing, and remove the flex shaft from the cable. Then it could fill up with oil, and act as KZ Lava Lamp.
sounds like we have come up with the exact same solution. i am still pondering if i will keep the stock tack since it will be of no use. but it will keep the original appearance, which i like. but if i only had 1 gauge (centered), i think it would still look better if it was in the original kz cup.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- mark1122
- Keep twisting it
13 Oct 2010 09:37
testarossa wrote:
sounds like a great idea :laugh:
but i was thinking more along the lines of a temp or 02 gauge.
mark1122 wrote:sounds like we have come up with the exact same solution. i am still pondering if i will keep the stock tack since it will be of no use. but it will keep the original appearance, which i like. but if i only had 1 gauge (centered), i think it would still look better if it was in the original kz cup.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
13 Oct 2010 19:52
Oddly enough, this same topic came up simultaneously in my build thread, and not of my doing. Nelson suggested, fitting a GPS or bicycle speedometer. The bicycle speedos are something I am quite familiar with. I even have one with a built in heart rate monitor. It would be interesting how many rpms the old ticker gains after a wheelie. :woohoo:
Some of the bike speedos have a backlight, but it is usually momentary to preserve batteries. They do have speed, odometer, trip odo, average speed, max speed, and some even have altimeters. Garmin actually builds a speedo/GPS unit that has some very interesting features.
Probably not the direction that I will go, but interesting options none the less.
I'm thinking along the lines of Acewell or other on the left gauge, and GPS on the right side. Time will tell. I'm afraid that adding a O2 monitor would cause me to become obsessive compulsive about my jetting/tuning. I wouldn't want that. Off to wash my hands for the 35th time since dinner. :laugh:
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- porchev914
13 Oct 2010 22:12 - 13 Oct 2010 22:14
I could not find the dimensions on this particular unit, but it was something that irishwill had mentioned to me. It is a nice looking stepper motor driven analog speedo display. He had planned on fitting this gauge in the stock housing like you'd like to do. If you need to fit a flange on the inside of the stock housing, let me know.
www.spa-uk.co.uk/design/speedo/
They also have matching electronic tachs. The price looks STEEP though :whistle:
FRANKEN Z!
Last edit: 13 Oct 2010 22:14 by porchev914.
- Old Man Rock
14 Oct 2010 04:23 - 14 Oct 2010 04:33
Here ya go....
Larry was thinking about the gutted cup as well back when... Might want to pm him on it for what he came across....
If need be, I can get some caliper dimensions on mine for ya... Let me know what you need....
EDIT: follow the link for dimensions.... 70mm x 60mm
NOTE: Acewell also makes a panel mount version that may suit your cup needs better....
www.acewell-meter.co.uk/Specifications/index.htm
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 14 Oct 2010 04:33 by Old Man Rock.
- testarossa
14 Oct 2010 06:37
Thanks guys. I think that the one I am looking at is a panel mount. It listed 64mm diameter x 41mm long IIRC. Seems like it would fit.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- Bdog
- Sweep the leg johnny!!!
17 Oct 2010 06:32
I have an Acewell question for those that have installed one. I am making a complete harness for my 650 and I need to know what wiring requirements these gauges have. Thanks. I assume it's coil feed, 12V and ground?
Brandon
Brandon
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- Old Man Rock
17 Oct 2010 06:42
Also depends on the model you get such as fuel sender...
These units come with idiot light inputs as well such as oil, turn signal, neutral, high beam etc....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Grantl
- KZRider is Da Bomb!!!
12 Nov 2010 10:46 - 12 Nov 2010 10:49
My son Alex just bought an Acewell 2853 to mount on his KZ750 L3. Looks like he will be doing the same changeout a OnkelB just did.
Problem is that we are both noobs to electrical work so we may have some really dumb questions for you guys.
When I say dumb questions, I mean very basic electrical stuff. Please be patient, we will try to provide pics as we go.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
1990 550 Zephyr
1994 KZ1000 P
Last edit: 12 Nov 2010 10:49 by Grantl. Reason: put wrong user name in thread
- testarossa
12 Nov 2010 10:56
Grantl, where did your son purchase his Acewell? Was he satisfied with the purchase?
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- Grantl
13 Nov 2010 00:04
He purchased the unit through Baja Designs located in San Marcos Ca. They say to allow 10 business days but shipped the unit within 3 business days.
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
1990 550 Zephyr
1994 KZ1000 P
- testarossa
13 Nov 2010 06:04
Thanks for the input.
It seems that there are a few Acewell owners here. I'm sure that collectively we can set you straight. Where are you going to post the photos? New thread, or in this one? BTW, I don't mind if you post them here. Hijack if you like.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
