Tail light out
  • Kapahulu
  • Kapahulu's Avatar Topic Author
Tail light out
11 Oct 2010 03:16 - 11 Oct 2010 03:17
#405898
My 1979 KZ1000 tail light is not working. That is, the running light doesn't work. The brake light does come on when I hit the brakes.
I changed the bulb and the tail light still was inoperative. Next, I checked the wiring to the tail light and went to the connector upstream from there, under the seat. Looks okay.
My question - is there a certain point in the harness that tends to cause this problem? Or do I just need to follow the wiring and use a multimeter to find out where the issue is?
I am not much of an electrican, if anyone can help that would be great.
2strokeworld.com
Last edit: 11 Oct 2010 03:17 by Kapahulu.
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Tail light out
11 Oct 2010 05:22
#405904
Tail light is normally a direct power feed off the ignition switch....
Since brake light is operating, assumption good ground to lamp assembly but not necessarily the bulb holder itself.... check and clean any oxidation where bulb ground contacts the holder.... DVM resistance continuity test for insuring frame/battery ground at same potential to bulb holder ground...
DVM for battery +Vdc when ignition switch is turned on.... DVM black probe on grounded frame or battery (-) post... Meter set to Vdc +20Vdc range...
Turn on ignition switch, measure running light connector for battery voltage... Follow this running light power feed from ignition switch all the way to the bulb holder power contacts.
Would need your exact wiring diagram but should be close enough to give you an idea....
77/78KZ1000 diagram....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Re: Tail light out
11 Oct 2010 05:29 - 11 Oct 2010 05:35
#405908
Under seat over rear fender, could connect working brake light feed into tail light connector to determine whether tail light bulb filament shines when brake is applied.
If not already done, would confirm voltage from harness wire where it connects to the wire going to the tail light.
Would also confirm tail light bulb filament is intact by using an ohmmeter.
Good Fortune! :)
Last edit: 11 Oct 2010 05:35 by Patton.
  • Old Man Rock
Re: Tail light out
11 Oct 2010 05:32
#405910
Anyone have a 79 KZ1000 wiring diagram?
Be interesting to see if there's a large difference....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Re: Tail light out
11 Oct 2010 05:47
#405916
  • MFolks
  • MFolks's Avatar
Re: Tail light out
11 Oct 2010 09:43
#405961
On most Kawasaki's, the color code for the rear lighting is:
RED,running or tail light circit.
BLUE(sometimes with a red stripe),the brake light circuit.
BLACK with YELLOW stripe, the ground circuit.
  • Kapahulu
Re: Tail light out
11 Oct 2010 11:13
#405975
Wow you guys are super helpful, thanks! It's Monday morning, I must do some work. I'll checkout the wiring this week and hopefully get it fixed easily.
Here's a picture of my KZ.
2strokeworld.com
  • Kapahulu
Re: Tail light out
19 Oct 2010 21:39 - 19 Oct 2010 21:39
#407688
Okay the solution was really simple - a burned out fuse. Replaced the fuse and now the running light works.
Also, the right turn signal and the right turn indicator on the dash are "always on" now with the fresh fuse.
Well that will be something else to check tomorrow. The bike did not come with front turn signals so they don't work anyways for now.
Aloha, Mike
2strokeworld.com
Last edit: 19 Oct 2010 21:39 by Kapahulu.
  • Old Man Rock
Re: Tail light out
20 Oct 2010 04:43
#407710
"right turn signal and the right turn indicator on the dash are "always on" now with the fresh fuse."...
Is Turn signal switched (left handle bar control) in the ON position?
Possibly the Hazzard switch is ON as well for it also uses the turn signals...
Normal if in or wired to the on position where it's recognizing one of the turn signal bulbs being out.... No blinky....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
