MSD ignition.
- otakar
MSD ignition.
07 Oct 2010 05:10
Has anyone used the MSD ignition on their bike? MSD has had four ignitions available for bikes. MC1, MC2, MC3, and MC4. The first three are just improved versions of each other. The last one MC4 is a programmable ignition somewhat different. On the MC1-3 ignitions they recommend using low resistance coils. Many of us use 3 Ohm coils and some of us use 2.2 Ohm coils on the later IC ignition bikes such as the "J" series 1000/1100s and the 750/4s. MSD recommends using 1.2-1.5 Ohm coils. I know that the MSD is a CDI ignition, but can someone explain to me what the significance of using a lower resistance coil would be, and if using a 0.7 Ohm coil would therefore make it even better? I know that they just want to sell me their #8204, 1.5 Ohm coils, but I want to know if I have a choice and use Dyna Brown (1.5 Ohm) or Dyna Blue (0.7 Ohm) coils? And also if this means that the lower resistance coils I use, the better off I will be?
Lou, I think that you might be able to answer this one, but I think that there might be others out here also. The MSD box is gi-normous and I will have a heck of a time finding where to mount it. Right now I am considering in front of the battery box, where the airbox used to be.
Otto
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- TeK9iNe
- What did you do!?!
Re: MSD ignition.
07 Oct 2010 07:32
I would just use the recommended range for coil input impedence 1.2ohm - 1.5ohm
Having too low a resistance will likely burn up the ignition, and too high will just create more coil heat and reduce life/spark quality.
The brown Dyna coils will be perfect, and your spark will be incredibly strong.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- otakar
Re: MSD ignition.
07 Oct 2010 09:19
This is a CDI ignition and reacts completely differently with coils than the ignitions we normally use. The coil dose not hold the charge as in our standard ignitions. The charge is held by the ignition box itself.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Re: MSD ignition.
07 Oct 2010 09:40
Well, I finally got hold of MSD. According to them, the lower the resistance in the coil the better. Apparently any of the Dyna coils will work just fine but the lower the resistance the better. The lower the resistance the coils the more massive the spark. MSD recommends the 1.5 Ohm coils because that is the lowest resistance dual tower coils they have. I guess it's time to pick up a set of Dyna DC9-1, Blue, .7 Ohm, coils. I was told that spark plug gap is not an issue with this ignition. The bigger the better. for both power and efficiency.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Jack
Re: MSD ignition.
07 Oct 2010 11:57
I've used MSD MC1's since the late 80's with Dyna S and Dyna coils- green 3 ohm for single plug and brown 1.5 ohm for dual plug heads.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- otakar
Re: MSD ignition.
07 Oct 2010 12:50
I plan on using the the Kawasaki ignition to trigger it and will use the .7 Ohm Blue coils.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- School Teacher
Re: MSD ignition.
13 Oct 2010 23:28
I have seen the blue coils on flea bay quite cheap(less demand?)in the past (nothing now when you want em) good luck.
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
1980 kz1000G1
- otakar
Re: MSD ignition.
14 Oct 2010 05:04
I talked to MSD, and they told me that ALL the Dyna coils will work with the MC1/2 ignitions. But, the lower the resistance the stronger the spark. They told me that it is designed for the use around their 1.5 Ohm coil for a 45,000 Volt spark, but will give even stronger spark with the lower resistance coils. For the time being I will use my 2.2 Ohm coils that I have installed and wait to pickup the .7 Ohm coils when available as you said, on fleaBay. I love using the highest possible voltage with the largest possible plug gap.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
