Dyna coil failure...overcharging system?
  • madmatt1
  • madmatt1's Avatar Topic Author
06 Oct 2010 17:35
#404661
I have had a set of Dyna coils (and Dyna S) on my 77 KZ1000 for the last four thousand miles or so. Driving home the other day, I suddenly lost two cylinders. I pulled all the plugs and engaged the starter, and sure enough just the 1 and 4 plugs have spark. Took the tank off and pulled the wires to the dead coil, and the connectors are oily and have green corrosion. The number four wire on the other coil is oily and a little green too, but that one was still firing. There is no visible cracks on the outsides of the coils. I can only assume that my regulator is bad and I am getting way too much voltage. Any input would be greatly appreciated!
1977 KZ1000 LTD
1979 KZ1000 LTD
1978 KZ1000A
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Dyna coil failure...overcharging system?
06 Oct 2010 17:39
#404664
Should be close or 100% the same a the 76 KZ900... Someone else can chime in if incorrect...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Old Man Rock
06 Oct 2010 17:41 - 07 Oct 2010 04:05
#404665
EDIT: Removed Image.... :pinch: :pinch: :pinch: :whistle:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 07 Oct 2010 04:05 by Old Man Rock.
  • madmatt1
06 Oct 2010 17:50
#404669
Thanks for the info! Hopefully she'll still be in the mood to start and run well enough on 2 cylinders to do the test!
1977 KZ1000 LTD
1979 KZ1000 LTD
1978 KZ1000A
  • Old Man Rock
06 Oct 2010 17:57
#404672
Coils, Dynamo and Rectifier can be checked with DVM (resistance measurements)... ;)
Granted, not as good as running but if severely damaged, dead short, open etc... the meter will detect this....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • otakar
  • otakar's Avatar
06 Oct 2010 18:13
#404678
I don't think that higher voltage would hurt the coils. My new MSD ignition pumps 400 Volts into the coils.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
06 Oct 2010 19:02
#404690
What the... ??? Why?
400 Volts... what kind of amperage?
:huh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • MFolks
  • MFolks's Avatar
06 Oct 2010 19:03
#404691
The Green Dyna 3 ohm coil(and maybe the other Dyna coils) use a 10-32 x 5/16" long screw.
If the supplied screws are too lost and replacements are used they maybe too long, they will bottom out before the screw gets tight.
Do you live in a humid,salty environment? Are the wires going to the coil properly crimped? I'd suggest checking the wiring for insulation damage too.
  • steell
  • steell's Avatar
06 Oct 2010 20:43
#404725
Did you switch the wires from the Dyna S to the coils around to verify that it is actually a bad coil? The Dyna S does have a tendency to go bad on just one side.
  • loudhvx
  • loudhvx's Avatar
07 Oct 2010 01:09
#404777
Old Man Rock wrote:
Pretty hard to get that starter to turn with a 20A fuse in the positive battery cable. :blink: :laugh:
  • loudhvx
  • loudhvx's Avatar
07 Oct 2010 01:18
#404778
:huh:
It's CDI. CDI systems hit the coils with a big spike of voltage. The coil just acts like a transformer unlike in a standard KZ ignition where it actually stores energy.
However, the coils in the standard KZ ignition also get a spike of several hundred volts on them right when the points open, or right when the igniter lifts the ground side of the coil.
In CDI, the module generates the high voltage, in standard (Kettering) ignition, the coil generates the high voltage. Both of these are on the primary side of the coil. The coil steps up this several hundred volt spike into several thousands of volts at the plugs.
After the spark initiates, the voltage (on primary and high-tension side) drops to a much lower level.
  • loudhvx
  • loudhvx's Avatar
07 Oct 2010 01:23
#404779
If the charging system is faulty and allowing the battery voltage to get too high, the coils will be able to stand the voltage, but the extra voltage causes more current, which causes more heat, and that is what can cook the coils.
With MSD or any CDI, the current is only in a super short pulse so there is no real heat issue to worry about. (Dyna S is electronic Kettering, not CDI.)
