first time wiring!!!!
  • steveo_4192003
  • steveo_4192003's Avatar Topic Author
  • 77kz650b-1
18 Apr 2006 03:05
#40407
i got a 77 650kz b-1
the wires are all over!
if i jump a few wire it will run, but then there is the rest of them!...
i want to know what i need to just to run the bike?
i tried to come up with this diagram but not sure if it could work! not to sure if i should use the brown wire from regulator for my toggle switch or straight off the battery? is brown even hot? enough juice?
please look at it and give me your feedback
if you have a diagram of the (bare minimun)wires, that could help!
i can go battery-less and get condenser also if thats best way to do it!
just need a diagram for condenser setup, and what kind, and were to get one!
also the reasone for this is starter is broke for now!!!!
wher do i get a good condensr from???
thanks all
Post edited by: steveo_4192003, at: 2006/04/18 06:07
Post edited by: steveo_4192003, at: 2006/04/18 06:44
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
  • loudhvx
  • loudhvx's Avatar
Re: first time wiring!!!!
18 Apr 2006 09:24
#40481
That look very good! You just need to hook up the brown on the regulator. I would recommend some fuses too, but only if you want.
Post edited by: loudhvx, at: 2006/04/18 12:26
  • loudhvx
  • loudhvx's Avatar
18 Apr 2006 09:29
#40483
You can't go batteryless on the 77 KZ650 without changing the alternator/regulator/rectifier, but you can use a tiny scooter battery like we did on this one.
  • steveo_4192003
  • 77kz650b-1
18 Apr 2006 11:45
#40528
thank you that was very very helpful!!!
  • steveo_4192003
  • 77kz650b-1
Re: first time wiring!!!! (solved)
19 Apr 2006 18:42
#40956
thank you very much, that worked great. got her running and drives pretty good!!!!
now for the head light and tail light, break, and thats it for now ( just to keep legal a night)!!!!!
  • loudhvx
  • loudhvx's Avatar
19 Apr 2006 22:21
#41016
That's great!
