Speedo and tach wigging out at high speeds
- Omaha Rider
27 Sep 2010 09:14
My tach and speedo do fine until i'm going around 70. Then they both begin to give outrageous readings of constant fluctuations. It's really annoying because I can't tell what RPM i'm at after around 6-7. They just start wigging out. Anyone know what could be wrong? Thanks a bunch
1978 KZ650 SR D
- TeK9iNe
- What did you do!?!
Re: Speedo and tach wigging out at high speeds
27 Sep 2010 09:58
"Wigging out" :laugh:
We used to use that expression for a meth addict that lived on our street! :laugh:
Anyways... They're wiggin cause thery're old. The magnets/mechanicals inside have worn past the point of being able to properly report to the needle.
These guys are yourbest option for help/repair: Z RESTO
Cheers!
Cheers!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
27 Sep 2010 10:56
Have you cleaned&lubed or replaced the speedo & tach cables lately? Ed
27 Sep 2010 10:57
Omaha Rider wrote:
If mechanical meters, might help to clean and lube cables.
- Omaha Rider
27 Sep 2010 11:11
650ed wrote:
yes I have
yes I have
1978 KZ650 SR D
- fixer5000
28 Sep 2010 15:08
if you have ever just added washers to tighten up the mounts remove them and replace the foam cushion between the mount and the gauges
1978 kz650b pretty much stock
massachusetts
massachusetts
28 Sep 2010 15:59
fixer5000 wrote:
Thanks to another member who suggested using a computer mouse pad.
- fordtruck
28 Sep 2010 22:43
Patton wrote:
That sounds like a great idea! I'll have to try that the next time I'm wrenching on mine. My guages flake out at speed too.
fixer5000 wrote:if you have ever just added washers to tighten up the mounts remove them and replace the foam cushion between the mount and the gauges
'77 KZ1000-MTC 1075 kit. Stage 1 port
- MFolks
28 Sep 2010 22:46
Probably a harmonic vibration causing the needles to read really wrong. Change the old,hardened,rubber dampners first before send the instruments off for repair.
- Kidkawie
- I bleed premix
29 Sep 2010 06:51
I fixed the loose mounts in my Z1 guages using some rubber washers from a plumbing repair kit. One of those universal type kits from Lowes.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- JR
29 Sep 2010 12:44
When I bought the beast 8 years ago the speedo would go crazy when it hit 40kph. I unscrewed the cable, undid the brackets etc and took it off. I shook it and it rattled. OK I thought, there's something rolling around in here. I cut the chrome ring which holds both halves of the speedo together. I opened her up and there was a little 12V bulb holder - did I mention the speedo lights did not work ? - rolling around and messing with the inner workings. I put the holder where it should be. I put the 2 speedo halves together and put the chrome ring back using PC7 Epoxy. I got new bulbs and everything is good since.
