Concerning Coils....
  • jonnygorman
  • jonnygorman's Avatar Topic Author
27 Sep 2010 07:04
#402200
I have an '81 kz750H which ran like a dream until last month. It has been sitting since. Anyhow, the symptoms just before dieing were as such: sudden trouble starting and drop in idle speed while idleing. just before her funeral she started, idled really slow, refused to pick up rpm under acceleration and died soon after. She now refuses to start. I performed all of the ignition tests in service manual and all test positively (even coils) despite the fact that I have zero sprak and one of the coils is cracked right down the center. I need to buy a new coil anyway (because of the crack) but I found it strange that both coils would go out at the same time, as none of the cylinders have spark. It's definitely not a fuel issue and she is trying hard to turn over. Are coils wired in a such a way that if one goes the other will not energize?
I would appreciate any help.
Thanks
Jon
P.S. Any coil brands/store suggestions?
  • Kawickrice
  • Kawickrice's Avatar
Re: Concerning Coils....
27 Sep 2010 08:47
#402216
Factory coils are known to crack and turn to toast. A set of Dyna Coils will get you back on the road if it is indeed the coils. If you don't have the cash for Dynas you could get some factory replacements but I would go for the Dyna's if at all possible.
My 2 cents
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Kapahulu
  • Kapahulu's Avatar
28 Sep 2010 02:08
#402391
I think there's another problem. One bad coil shouldn't keep the other coil from working. Did you test all four plugs for a spark?
2strokeworld.com
  • jonnygorman
28 Sep 2010 06:19
#402412
Yes, all four plugs tested and no sparks across the board. Tested the pickup according to the book, ohlm readings from blue to black and red to yellow are 500. The plugs are new, but having everything go at one time is confusing me.
Thanks
Jon
  • Motor Head
  • Motor Head's Avatar
28 Sep 2010 06:31
#402413
You need to test to see if your points set is "Grounding & un-Grounding" as this with 12v to the coils will give spark. Test light or meter, either will tell you. Test light to confirm 12v to coils from ignition, or meter, then the negative/ points side of coil/ to see if when motor rotates points show ground then no ground as they go from closed to open. Maybe you got the wire hooked up on the wrong side of the insulator on the points terminal, inside the side cover. If you use a test light across the coil terminals it should flash as the motor rotates. If no 12v to coil, start checking the fuses, clips, then kill and ignition switches.
  • loudhvx
  • loudhvx's Avatar
28 Sep 2010 08:49
#402439
Dyna gray 2.2-ohm coils are the ones for your bike.
Normally, if one coil goes, the other should still work.
Maybe buy one new coil. Then you can use it for testing by swapping it in for each of the old coils.
If the coil doesn't fix it, then it may be the igniter.
If it is definitely the igniter, then you can get one on ebay or try to build one.
home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html
How are you checking for spark, to know there is none?
