1978 750B
- 78kztwin
1978 750B
24 Sep 2010 06:17
I have a 750B that's not charging. The alternator is putting out 3.5, the battery is putting out 13 until throttled, then drop to 10. the voltage regulator is staying at 11 without change. Any ideas. Also, does anyone know what the cylinder type thing is that one of the wired from the regulator goes to. There is also the positive terminal going to it....help
78 kz 750 twin work in progress
- TeK9iNe
- What did you do!?!
Re: 1978 750B
24 Sep 2010 06:54 - 24 Sep 2010 06:57
Not being condescending, but the alternator is putting out 3.5 what? :laugh:
Generally the voltage output form an alternator/stator is measured in AC Volts, and should produce more than 50VAC on any combination of its output wires, after approx. 4000rpm.
Is the battery new? If its more than a couple seasons old, it should be thoroughly tested to determine actual capacity, or replaced.
Charging system checks a confirmed at battery measurement.
Should be 12.6 VDC OFF (having sat overnight).
Around 13 VDC Idling.
14.5 VDC when revving past approx. 4000rpm.
The wired cylinder thing is probly your rectifier.
Best of luk.
Best of luk.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 24 Sep 2010 06:57 by TeK9iNe.
- steell
Re: 1978 750B
24 Sep 2010 10:56 - 24 Sep 2010 10:58
The 78 750B has a combined reg/rec, and the round cylinder thing is the starter solenoid.
Other than that, TeK9iNe pretty much covered it.
Check the reg/rec ground, if it's not grounded it won't work.
Last edit: 24 Sep 2010 10:58 by steell.
- TeK9iNe
Re: 1978 750B
25 Sep 2010 06:27
steell wrote:
:laugh: :laugh: Yep, that'd be right.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- 78kztwin
Re: 1978 750B
26 Sep 2010 17:22
it turns out the genius I bought it from had the ground wire going to the positive battery terminal....thank you
- Motor Head
Re: 1978 750B
26 Sep 2010 17:29
Good you found the problem. Have you confirmed the charging figures as per the service manual?
Or are you just out enjoying the ride on a old Kaw?
- MFolks
Re: 1978 750B
26 Sep 2010 19:17
Every Japanese motorcycle I've owned had a Negative ground. Some of the British bikes had Positive ground just like some of their cars. It makes troubleshooting real "Interesting".
- 78kztwin
Re: 1978 750B
18 Oct 2010 06:43
I would enjoy riding it but the carb is all messed up. The main jet is soldered in. I need to find another float bowl. any ideas...
