KZ Simple Wiring Help
  • DangerMan
  • DangerMan's Avatar Topic Author
Re: KZ Simple Wiring Help
24 Sep 2010 10:44 - 24 Sep 2010 10:50
#401423
loudhvx wrote:
I can draw up a diagram similar to what Leon posted, but I need to know if you are running points? Also you mentioned a combo regulator rectifier. Is that confirmed. Can you post a pic of the reg/rec and maybe someone here can confirm it's a combo or a stand-alone reg or rec?
YOU DA MAN!!!
I dont have a pic with me, But the part is: kokusan RS2127. You can see it in the main photo of the bike, its Rightside of the battery tray.
I have a pretty good feeling that its not a combo.... the guy I bought it from told me it was but.... it doesnt look like one at all. Anyway, I also have a 12v Reg/Rec combo off of a cb900 here. I was givin it and a crappy little drawing and told that "It SHOULD Work" :laugh:
I Can try it, Ill Send you some pics of it if you think it might.
THANK YOU!!!
this pice is the cb900 REG/Rec Combo I Was Givin.
Last edit: 24 Sep 2010 10:50 by DangerMan.
  • DangerMan
24 Sep 2010 10:53
#401428
Heres the "crappy drawing" i mentioned earlier.
I Was told i could run the CB900 Reg/Rec like this
  • TerryK
  • TerryK's Avatar
24 Sep 2010 10:54
#401429
54mm carbs?
I think not. :P
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • DangerMan
24 Sep 2010 11:02 - 24 Sep 2010 11:16
#401434
As for the Points question..... i Have no idea! LOL
Sorry. Its more than likley the origional ignition system for 77'. Whatever that is.
Heres a pic of a regulator like mine. Identical
Last edit: 24 Sep 2010 11:16 by DangerMan.
  • DangerMan
24 Sep 2010 11:19
#401443
  • loudhvx
  • loudhvx's Avatar
24 Sep 2010 11:19
#401444
That regulator on the bike does look like the original regulator-only... not a combo. So there is no rectifier anywhere? Probably removed.
If you are near the bike, the small cover on the right end of the motor is where the ignition is. Open it and see if there are points in there.
That reg/rec combo from the CB900 doesn't look like it will work. Your bike doesn't have the green and white wires going to the alternator. They might be for a field coil, which your bike does not use. So that regulator is for a different type of alternator.
Looks like you will need a combo reg/rec for a 77/78 KZ1000. See if OregonMotorcycleParts.com has one. If they do, it'll probably be the least expensive one out there with a good warranty.
  • DangerMan
24 Sep 2010 11:23 - 24 Sep 2010 11:40
#401446
Ok, just got offthe hook w/ an old guy that live about 3hrs away. Hes got the rec. for $35. Sounds like a pretty knowledgable old salt. Iwas just hoping fo a quick fix. there a local Run tomorrow. oh well. Thanks
BTW,, its A 77' KZT00a
Last edit: 24 Sep 2010 11:40 by DangerMan.
  • loudhvx
  • loudhvx's Avatar
24 Sep 2010 11:28
#401447
By the way, I don't know why I thought it was a 77 or 78, but do we know what year it is for sure? Or at least the amnufacture date from the frame neck?
  • DangerMan
24 Sep 2010 11:33
#401449
77' kzT00a
  • DangerMan
24 Sep 2010 11:38
#401452
77' KZT00A
  • loudhvx
  • loudhvx's Avatar
24 Sep 2010 12:00 - 24 Sep 2010 12:01
#401457
I'm assuming that is from the serial number. Does anybody know if that means KZ1000A or KZ1000B? I thought the KZ1000A had spokes, according to the filebase photo. The 77 KZ1000B (LTD) had mag wheels.
Either way, I think the wiring is basically the same. Here is a preliminary diagram for the seperate regulator and rectifier. If the regulator has pink, Yellow, and blue wires to the alternator, then you have to keep those wires in the correct order.
If you get a combo later, then it will probably have three yellows and it doesn't matter which pink, yellow, or blue wire goes to which of the three yellows on the combo.
Last edit: 24 Sep 2010 12:01 by loudhvx.
  • loudhvx
  • loudhvx's Avatar
24 Sep 2010 12:02 - 28 Sep 2010 08:40
#401458
see version 2 below
Last edit: 28 Sep 2010 08:40 by loudhvx.
