dyna ignition question
Re: dyna ignition question
20 Sep 2010 12:21
#400352
kz1k wrote:
i talked to larry at dynatek. he is sending me a trouble shooting guide for the system i currently have. if it does not work he will upgrade me to the dyna s system for 69 bucks if i send him the old ingition box and sensor plate.
so once i get my damn bike back...lol ill trouble shoot it.
what i dont understand is that if the dyna s replaces the box...it only has 2 wires right? how would that hook up to 2 coils that have 4 wires?
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
20 Sep 2010 12:21
#400353
cool patton, and no that was not mentioned to my memory. the trouble shooting guide is pretty simple. i run it by you guys when i get the damn bike back...lol
1978 KZ1000A2
20 Sep 2010 12:23
#400355
20 Sep 2010 12:24
#400357
20 Sep 2010 12:36
#400359
Patton wrote:
Dyna-S rotor has an embedded magnet, sometimes difficult to see, about as big around as a pencil eraser.
The magnet at 9 o'clock position aligns with left Dyna-S module to unground whichever ignition coil is firing the two outside spark plugs #1 and #4.
The magnet at 3 o'clock position aligns with right Dyna-S module to unground whichever ignition coil is firing the two inside spark plugs #2 and #3.
Dyna-S ignition requires switched battery positive voltage to function, supplied by a red wire spliced into a bike harness wire (often just before the dual connector feeding battery positive to the coil primaries (perhaps a red/yellow wire).
Sometimes there might be an unused harness wire connector which could be adopted for supplying switched battery positive voltage to the Dyna-S. Just plug the Dyna-S red wire into such otherwise unused connector.
Good Fortune! :)
  • kz1k
20 Sep 2010 12:43
#400361
your awesome...thanks
1978 KZ1000A2
  • kz1k
20 Sep 2010 12:54
#400365
ok, this is from dyna to see if my ingition is bad......"module/coil test: disconnect the sensor wires and touch the female(module end) of the input wires to ground. do not touch red 12 volt wire to ground. you should get a spark at the appropriate spark plugs everytime the inputs are grounded.if not it indicates a bad electronic module, a bad coil, or a problem somewhere in the wiring not associated with the sensor plate."
anyone got this in lamens,. "retard" terms?
1978 KZ1000A2
  • Motor Head
  • Motor Head's Avatar
20 Sep 2010 13:10
#400370
I think you should visit here:http://www.dynaonline.com/skins/downloads/Default.aspx
Down load the Dyna 3 stuff, and read a bit, should be very straight forward.
  • kz1k
20 Sep 2010 13:13
#400372
niiiicccceee, thanks
1978 KZ1000A2
  • loudhvx
  • loudhvx's Avatar
21 Sep 2010 04:23
#400515
Dyna is such a good company to deal with.
That is a great deal. Send them your Dyna III stuff and let them test it. If it's bad, they'll sell you a Dyna S for like 1/2 price... good deal.
Patton and others have great write-ups on how to install the Dyna S once you get it.
(I haven't tried the GM modlues with a Dyna III ignition yet.)
  • Motor Head
23 Sep 2010 14:45
#401225
Did you send your Dyna in for testing or an upgrade?
While the heads at Larry's you could have this done.
$ permitting.
  • kz1k
23 Sep 2010 14:59
#401231
$ permitting.
i still need to see if mine are ok when wired correctly. if i were to guess its so old its bad. plus, i wont need spark for a while....getting the cylinders honed/cleaned, and measuring, plus the head being done and getting new timing chain is first on my list. ill probably work from the bottom up...ya know.
i am certain i will be sending my ignition out to dyna and upgrading.
1978 KZ1000A2
