dyna ignition question
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
20 Sep 2010 10:55 - 20 Sep 2010 10:55
#400326
hi guys. as most of you know i am having a few bumps in the restoration road. i have 1 green 3 ohm dyna coil. i am purchasing another used 1 here shortly. im not sure yet, but if my dyna 3 electronic ignition is bad, do i have to use the same one? i have the black one shown in the pic. i guess what i am asking is if i cant find another one like i have can i use another one, and which one? btw i also have a new but used wire harness comming. thanks Joe
1978 KZ1000A2
Last edit: 20 Sep 2010 10:55 by kz1k.
  • loudhvx
  • loudhvx's Avatar
Re: dyna ignition question
20 Sep 2010 11:11
#400331
You could also use a Dyna S ignition. It replaces the timing plate and eliminates the black box. It uses the same coils as the Dyna III.
  • Motor Head
  • Motor Head's Avatar
20 Sep 2010 11:11 - 20 Sep 2010 11:26
#400332
loudhvx has a write up on how to use 2 HEI, those are from the older GM cars/ Trucks, Modules with the stock Kawasaki pick-up coils. Shoot him a PM and he can hook ya up. Easy to do with you Dyna Pick-ups if they are still good, I would think anyway. Just send him a PM he will set you on a course to get something going.
Last edit: 20 Sep 2010 11:26 by Motor Head.
  • kz1k
20 Sep 2010 11:19
#400334
thanks
1978 KZ1000A2
  • kz1k
20 Sep 2010 11:34
#400340
so if i get the dyna s ignition i dont need the black electronic ignition box? is there diff models? what do i need to look for? dont wanna grab the wrong thing.
1978 KZ1000A2
  • kz1k
20 Sep 2010 11:46
#400341
i went on z1 and didnt see a dyna s ignition....they have the whole set with the dyna 2000, but its 400 bucks. i just need the ignition.
1978 KZ1000A2
  • kz1k
20 Sep 2010 11:48
#400342
this is what i have...............
1978 KZ1000A2
  • kz1k
20 Sep 2010 11:48
#400343
1978 KZ1000A2
  • Motor Head
20 Sep 2010 11:51
#400344
kzrider.com/index.php?option=com_artbannersplus&task=clk&id=2
Is what you have, and a phone call to them can find out availability, or if any parts are available.
20 Sep 2010 11:56
#400347
Click here > www.z1enterprises.com/detail.aspx?ID=200
Wouldn't yet give up on the existing Dyna III which might still be serviceable.
Good Fortune! :)
  • kz1k
20 Sep 2010 12:03 - 20 Sep 2010 12:09
#400348
i talked to larry at dynatek. he is sending me a trouble shooting guide for the system i currently have. if it does not work he will upgrade me to the dyna s system for 69 bucks if i send him the old ingition box and sensor plate.
so once i get my damn bike back...lol ill trouble shoot it.
what i dont understand is that if the dyna s replaces the box...it only has 2 wires right? how would that hook up to 2 coils that have 4 wires?
1978 KZ1000A2
Last edit: 20 Sep 2010 12:09 by kz1k.
20 Sep 2010 12:16 - 20 Sep 2010 12:18
#400350
kz1k wrote:
Terminal screw head on Dyna coil primary is dangerously near the coil mounting spacer (usually metal). Am thinking this was mentioned but not fully addressed in one of the other threads.
Here, seems to be something wrapped around the spacer (presumably for insulation).
Methods vary. Some replace metal spacers with plastic or nylon spacers, use a piece of rubber, etc.
I just use tie wraps around the spacers (see right pic below).
Good Fortune! :)
[Click on image to enlarge view.]
Last edit: 20 Sep 2010 12:18 by Patton.
