77 650kz electrical????(solved)
- steveo_4192003
- 77kz650b-1
16 Apr 2006 17:12
i got a 77 650kzb1 from a freind and wiring is all messed up!
having a problem with wiring diagram!!!!
in the diagram the yellow/red wire from the starter relay ties into to a black and yellow, that goes to the regulator , rectifier , a ground wire! (follow it)
the problem is that i did it that way, and almost bunrt it up.. is the black wire from the starter relay a ground or ?
i want to take everything off except charging system!!
has anyone got a modded print of this or should i make my own?
C:\Documents and Settings\Owner\My Documents\My Pictures\bike wires 2.JPG
Post edited by: steveo_4192003, at: 2006/04/16 21:05
Post edited by: steveo_4192003, at: 2006/04/19 21:39
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
- The Milkman
Re: i dont get it!
16 Apr 2006 17:21
I don't get your avatar either,, this isn't a political forum. At least most of us try not to make it one. As far you the electical problem, it would help if you would give us some sort of information on what " im having a problem with a small part of it" means???
- steveo_4192003
- 77kz650b-1
Re: i dont get it!
16 Apr 2006 18:22
sorry about lack of info!
got disconnected
the bike is a 1977 650kz b1
i got it from a freind and it sat for a while in a garage. i seen the wires are all over this bike, not going to anything.
i want to take off everything electrical (if i can) except charging system
what do i need to just make the bike run?
anyone with a modded print?
all help will be greatly appreciated
got disconnected
- BSKZ650
Re: i dont get it!
16 Apr 2006 18:23
what was the problem to start with? I have a 77 650 and the books also, havent looked at the book, but I am sure between the bike and the book it could be fixed
77 ltd1000, current rider
76 kz900, just waiting
- steveo_4192003
- 77kz650b-1
Re: i dont get it!
16 Apr 2006 18:30
the bike will run, but only idles and when i give it gas it dies! needs re wired they are all over it, and a little tlc..
not to sur why it was parked ,but it will run and for a good price, i couldnt say no!!!!
- Tazzmann
Re: i dont get it!
16 Apr 2006 21:00
Look at the wiring diagram for your model on
www.kz650.info
and see if it matches yours. It looks like you have three black wires coming off the starter relay. One goes to the battery, one goes to the starter motor and one goes to the starter lockout switch. The red/yellow meets up with ground (black/yellow).
Hope this helps!
Hope this helps!
- steveo_4192003
- 77kz650b-1
Re: i dont get it!
16 Apr 2006 22:13
i have two black and one red/ yellow off the starter relay.
but when i try hooking them up they ground out and smoke!!!
what is the black wire off the starter relay? ground or power? and red/yellow?
i did it the way the manuale said and it wont start!
i do it my way and it starts
( my way both leads from coils to battery and starts right up for a few moments til i hit the gas)
it will idle but not to long
do i need a battry or can i take it out, and rewire it so i can just use the kick start?
i dont want lights or anything just spark and charging system to run it, is this possible
any try this before?
- loudhvx
Re: i dont get it!
16 Apr 2006 23:05
The starter solenoid circuit is one of the times when Kawasaki uses black as a hot wire. The black wire from the start button to the solenoid will have 12 volts on it when you hit the button. There may be a lockout switch on the clutch lever. If so, the black wire goes through that switch too.
Here's a diagram for a bike I wired. It just has charging system, electronic ignition, and lights.
Post edited by: loudhvx, at: 2006/04/17 02:07
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Tazzmann
Re: i dont get it!
17 Apr 2006 09:21
loadhvx has it right. Those (the black) are not grounding wires, those are hot wires. One should head to the battery and one should head to the starter lockout which is a switch in the clutch handle. One thing that I have seen with these lockout switches (the same type were used on the 440 for a front brake light switch) is that if put together incorrectly, they can short out to the handlebar which is ground. If no-one has messed with that switch, then it should be fine.
On my 650, I haven't even used the starter relay yet (I am waiting on one), so I don't know if mine even works yet. I DO know that if it is having idling problems it could be due to a multitude of things from carbs, to points/condensers, to timing.
Not sure if I helped or not, but just thought I would pass on more info.
- steveo_4192003
- 77kz650b-1
Re: i dont get it!
17 Apr 2006 11:15the red and yellow from starter relay, i assume that is the ground for it, it goes to the yellow and black!!!
and black is the hot wire for starter relay right???
Post edited by: steveo_4192003, at: 2006/04/17 14:19
- loudhvx
Re: i dont get it!
17 Apr 2006 11:21
steveo_4192003 wrote:
Yeah, it's crazy, but many KZ's are like that. At first I thought someone re-wired my bike wrong but that's how they are.
1981 KZ550 D1 gpz.
Other links.
Other links.
