we have fire.......
Re: we have fire.......
17 Sep 2010 19:52
kz1k wrote:
Here's the wiring diagram from Dyna III installation guide ---
...had it hooked up a few diff ways... it did spark once, but then when i tightened the nuts down it stopped working. its something simple.
- elfmagic17
17 Sep 2010 19:53
quote]i had it hooked up a few diff ways... it did spark once, but them when i tighned the nuts down it stopped working. its something simple.[/quote]
What nuts? on the coils? Could be grounding out on something when the nuts are tight, check and see if they need isolators.
Kenny Hicks
74 Honda CB550
74 Honda CB550
- MFolks
17 Sep 2010 20:02
The stock Kawasaki ignition coils on the Kz1000,and Kz/GPz 1100's have two bolts on each coil with spacers with 1/4" quick disconnect electrical conections(male tabs).
On the aftermarket Dyna coils, the same mounting hardware is used but the electrical connectors are 10-32 screws that come close to the bike's backbone.if the supplied screws are lost and the correct ones are not used, there is achance the screws will bottom out before the fastener gets tight.
I believe the correct terminal screw length is 5/16", a 3/8" screw would be too long.
- kz1k
- You Cant Fix Stupid!
17 Sep 2010 20:49 - 17 Sep 2010 21:06
elfmagic17 wrote:
What nuts? on the coils? Could be grounding out on something when the nuts are tight, check and see if they need isolators.[/quote]the nuts on the wire harnesses where the power cable is.
quote]
1978 KZ1000A2
Last edit: 17 Sep 2010 21:06 by kz1k.
- Old Man Rock
18 Sep 2010 07:01
What he's speaking of is the Coil frame mounting bolt through the coil plates... See how close it is to the +12Vdc terminal....
With the Dyna coils, you have to raise the coil slightly using spacer tube... If it's metal it's conductive... Henceforth you use a heat shrink tube or tape where it's not shorting the +12Vdc to frame ground....
See Images...
See Images...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- elfmagic17
19 Sep 2010 20:18
[/quote]the nuts on the wire harnesses where the power cable is.[/quote]
Sorry, i'm not too sure of the nuts you speek of, can you open your photo in paint or some program and circle the nuts you are talking about might be helpful to all of us here?
Kenny Hicks
74 Honda CB550
74 Honda CB550
- elfmagic17
19 Sep 2010 20:22
Oh and dude, scotch locks are bad news they only corrode and/or cut the wire and cause more problems I'd soldier and shrink or butt connect any that exist.
Kenny Hicks
74 Honda CB550
74 Honda CB550
