we have fire.......
- kz1k
- You Cant Fix Stupid!
we have fire.......
17 Sep 2010 15:54
ok a guy from craigslist came over for free and wired my bike. we have dash lights and push button start. but the dayna coils and the after market dyna transfer case was suggested to go back to factory. it seems the sparks fire when you touch the wire withohght pressing the button. what would a factory transfer case and coils cost me for my bike.
1978 KZ1000A2
- kz1k
Re: we have fire.......
17 Sep 2010 16:01
also i was told to get rid the the dyna crap. get a stock ignition, points plate, 2 sets of points, condensors and stock coils/ what will that run me?
1978 KZ1000A2
- kz1k
17 Sep 2010 17:50
see in the pics if you hook up the coil to the positive it fires the spark plugs without pressing the start button. why is this?
1978 KZ1000A2
- kz1k
17 Sep 2010 17:51
1978 KZ1000A2
- kz1k
17 Sep 2010 17:51 - 17 Sep 2010 17:52
1978 KZ1000A2
Last edit: 17 Sep 2010 17:52 by kz1k.
- Old Man Rock
17 Sep 2010 18:07
Dyna is crap....? :ohmy:
Not sure who gave you that tid bit of advice but I as well as many others have had good results using Dyna coils and ignition modules... Oh well...
Z1 has OEM style coils and ignition components...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
17 Sep 2010 18:27
Is Dyna III correctly wired?
Click > www.dynaonline.com/skins/downloads/instruct/D32-1_32-2.pdf
It's supposed to work like this -- ignition coil charges when grounded and fires through the spark plug wires when ungrounded.
On running engine, batt+ feeds continuously into coil.
The other small wire goes through the Dyna III controller box to a module under the points cover which grounds and ungrounds the coil as the crankshaft rotates.
It's not uncommon with Dyna ignition to get a random firing when ignition is switched ON and OFF.
Would not yet give up on the Dyna III.
If new ignition is ultimately deemed necessary, would go with Dyna-S instead of reverting to points.
- kz1k
17 Sep 2010 19:12
well i figured out how to get it to work, but now i have no spark...how come?
1978 KZ1000A2
17 Sep 2010 19:28 - 17 Sep 2010 19:31
kz1k wrote:
If coils are producing high intensity voltage, no spark at plug tips may result from an issue in the secondary loop such as faulty plug wires, caps, plugs, or related connections.
Last edit: 17 Sep 2010 19:31 by Patton.
- kz1k
17 Sep 2010 19:39
Patton wrote:
i had it hooked up a few diff ways... it did spark once, but them when i tighned the nuts down it stopped working. its something simple.kz1k wrote:well i figured out how to get it to work, but now i have no spark...how come?
1978 KZ1000A2
- Old Man Rock
17 Sep 2010 19:50
Engine and Dyna ignition module grounded?
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- MFolks
17 Sep 2010 19:52
Look at how the ignition coils are mounted, the terminals are very close to the frame backbone and may have shorted out. Check the fuses too as these older fuses can be a real pain to troubleshoot. They may look good but have failed internally.
